Water pump bolt torque??
Old Aug 2, 2013 | 10:57 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default Water pump bolt torque??
Having a gasket seal issue with a 5.3
Replacing the pump this week as its too much work to do for just a gasket
Most my experience is with Gen 1 stuff dont want to over/under torque these gaskets and have it seep again
Any sealers needed or put on dry?
Surprised to find ACDelco pumps are made in China now 1 yr warranty only, and almost 300!! Airtex is still made in America with lifetime warranty found one for 100 and the housing for 60. Give it a shot.
BTW engine has almost 150k, typical DD use
Should I bother with a timing chain at this point or let it ride?
Old Aug 8, 2013 | 11:54 PM
cv67's Avatar
cv67
St. Jude Donor '05
Noone spins wrenches?
Jobs done
Old Aug 9, 2013 | 09:11 AM
DIXZ's Avatar
DIXZ
Water Pump Bolts (1st Pass) 15 Nm 11 lb ft
Water Pump Bolts (fin Pass) 30 Nm 22 lb ft
You don't need sealer.
To Water pump bolt torque??
