What ATF do you use?
Old Aug 6, 2013 | 06:29 PM
zeke2u's Avatar
zeke2u
Default What ATF do you use?
I have a low-mileage (26K) Z06 that I recently 're-cycled' (bought as a salvage vehicle). It has sat without driving since last October. And, being low-mileage, I imagine it wasn't the first time it sat for an extended amount of time. So, I'm getting very small amounts of leakage from the transmission (from the joint between the transmission and differential) - I'm almost certain the seals dried-out from sitting so long. I'm going to top her up with new ATF and see if I can get the seals to seal with use. I'm just curious as to what fellow members use in their transmission, Dexron III or VI?
Old Aug 6, 2013 | 07:43 PM
thumpinc5's Avatar
thumpinc5
I own a transmission shop that specializes in race 4L60Es. The ONLY fluid we recommend is Dexron III / Mercon or "Dex III" as it's called now. We do not suggest synthetic or the use of any additives.
Frank
Old Aug 6, 2013 | 07:46 PM
racebum's Avatar
racebum
redline atf4
Old Aug 6, 2013 | 07:49 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Dexron III is what your owner's manual recommends, however, Dexron VI has since superseded Dexron III, beginning in 2005.
In my opinion, Dexron VI is a better choice. It is a synthetic blend, and has greater thermal stability than Dexron III.
Old Aug 6, 2013 | 09:24 PM
zeke2u's Avatar
zeke2u
Quicksilver Vert 01 - Is Dexron VI compatible with III? Or should I drain all the present fluid and replenish with the Dexron VI? Is this the Canadian GM product or are there other alternatives?
Old Aug 6, 2013 | 09:27 PM
dbaker's Avatar
dbaker
Originally Posted by 8VETTE7
Amsoil Torque Drive Synthetic ATF. Takes about 3.8 quarts.
Yep....
\db2
CAROLINA
Old Aug 7, 2013 | 12:32 AM
bob22z06's Avatar
bob22z06
I had the same problem in mine before mine is low mileage too it started to leak between the trany and differential ...I fixed it.....it was fearly easy job...remember there is no seal or gasket between them two they only used some kind of sealer when they built it so my guess it wears off after time...so what I did put the car up on jack stands then lossened all the bolts that hold them two Just like an 1/8 inch then I cleaned it dry , u have to let all the fluid to leak out I even used a rag to dry it too u have to make sure that both points are completly dry ..Then I bought from auto zone its called (Permatex brand) 1 minute gasketmaker its made to seal differentials, water pupms and other squizze some in the crack not to much u don't want that sealer to fall in into your trany and tight all the bolts back up and I left it sit for a little bit then I feeled it up with fluid I used (mobil 1 ATF synthetic fluid) because it was cheep and i wsnt sure if i fixed the leak didnt feel like wasteing good fluid...Its been almost a year no leak....good luck
Old Aug 7, 2013 | 02:19 AM
tak06's Avatar
tak06
Amsoil Torque Drive Synthetic ATF in my '02Z., shifts are buttery smooth compared to the OEM fluid.
Old Aug 7, 2013 | 03:02 AM
Turbooo2u's Avatar
Turbooo2u
Guess I must have missed something. All along I thought that Z06's all had manual transmissions............
They do but some areas of the rear end take ATF fluids. Welcome newbie.
Old Aug 7, 2013 | 07:53 AM
Quicksilver Vert 01
Dexron VI is compatible with, and will mix with all Dexron III fluids.
I would drain the old fluid first, unless you are just topping off the fluid level.
GM holds the license for the Dexron VI specification. Other ATF brands are also available, designated as Dexron VI, in the US and Canada.
Old Aug 7, 2013 | 09:14 PM
RedZMonte's Avatar
RedZMonte
NO. Use only Dex III labled Oils or GM Manual Trans Fluid designed for the car..
dex VI is not good for the Vette Trans from everything i have read on here. now it works great in the auto transmissions but not in the MT's
I run Valvoline Dex III, feels stock.
S
Old Aug 7, 2013 | 10:15 PM
Ohyoufan's Avatar
Ohyoufan
I put Torque Drive in my 99' FRC (which have the paper blockers that aren't suppose to take to synthetic well) and I can't describe the difference it made in my transmission. My transmission is quiet as a mouse now and the shifts are sooo smooth. It's going 20,000 miles strong now.
Old Aug 7, 2013 | 11:16 PM
racebum's Avatar
racebum
there's something to the dex3 thing
the old XJ jeep cherokee was spec'd with dex2 and dex3 is 100% compatible
those transmission grenade with dex 6
there has to be a difference
Old Aug 7, 2013 | 11:52 PM
bob22z06's Avatar
bob22z06
So if I'm using the Mobil 1 ATF synthetic fluid. ..it seems to shift fine only little harder when its cold. ..am I ok or I should change it?....
Old Aug 8, 2013 | 08:45 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
The "rear end" takes GEAR OIL......the transmissions take Dexron III.
Old Aug 8, 2013 | 11:45 AM
Mickeyrx70's Avatar
Mickeyrx70
Just changed mine a couple weeks ago. You can get it online along with a hand pump matched to Amsoil containers. See CF member Toque's website for some great tips on changing the transmission & differential oil.
Old Aug 9, 2013 | 01:09 AM
_zebra's Avatar
_zebra
let me know how it goes because mine's been doing the same thing for about a year now. it started kinda slow, but now i can make a smear a foot wide within a week or two.
To What ATF do you use?
Old Aug 9, 2013 | 01:13 AM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
Pennzoil Synchromesh Fluid in the yellow bottle
Old Aug 9, 2013 | 07:04 AM
zeke2u's Avatar
zeke2u
I've read that the GM Synchromesh Fluid is the same as Pennzoil's. Also, it seems to work/perform well in Getrag manuals. The question is why do manufacturers continue to recommend ATFs when the MTFs work so well?
Old Aug 9, 2013 | 08:38 AM
leadfoot4's Avatar
leadfoot4
Possibly because the ATFs are a little thinner, create 0.001% less friction in the transmission, and they're looking to extract every last smidge of fuel mileage, to keep the EPA happy.....
