Quick oil question
Old Aug 6, 2013 | 08:12 PM
bwill03z's Avatar
bwill03z
Default Quick oil question
I hate to even mention the word oil on this forum but... Been using Mobil 1 5w30 awhile now and was wondering what would be the next step up in thickness, 5w40? I know the M1 5w30 is a little thinner now than in the past so thats why I'm thinking about changing.
Old Aug 6, 2013 | 09:53 PM
Zorlac's Avatar
Zorlac
I'm not sure its thinner now but from what I understand some of the additives are a lower quantity.
Old Aug 6, 2013 | 10:21 PM
racebum's Avatar
racebum
what's your oil psi at idle with 212deg 30w oil. if it's over 25lbs you're fine for street driving
if you're tracking the car 40w will have more film at higher temps. but, if you're tracking the car you change the oil before and after the event.
Old Aug 7, 2013 | 01:11 AM
onlyavette's Avatar
onlyavette
Now you've gone and done it!
Old Aug 7, 2013 | 07:15 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Aug 7, 2013 | 09:14 AM
bwill03z's Avatar
bwill03z
Lol I'm def not trying to start another long oil debate I just want to know what weight is close to 5w30 but is just a little thicker.
Old Aug 7, 2013 | 12:00 PM
onlyavette's Avatar
onlyavette
I use Pennzoil Ultra 5w30 in winter and Pennzoil Ultra 10w30 in summer. On the track or not.
That may change when I no longer use stock valve train and stock crank and cam bearings.
That's all I am willing to say without fearing for my life.
Old Aug 7, 2013 | 12:51 PM
lionelhutz's Avatar
lionelhutz
Starting with 5W30, increase the 5 to get thicker oil when cold or increase the 30 to get thicker oil when hot. I doubt you want thicker oil when cold so 5W40 would be your choice.
Old Aug 7, 2013 | 02:13 PM
onlyavette's Avatar
onlyavette
I'm outta here.
Old Aug 7, 2013 | 03:35 PM
3boystoys's Avatar
3boystoys
Why do you THINK you NEED thicker?
Old Aug 7, 2013 | 03:59 PM
OneCylinder's Avatar
OneCylinder
St. Jude Donor '13
The viscosity (thickness) has not changed it is 5-30. It is the ZDDP (wear protection additives) that has been reduced. A higher viscosity (5-40) will probably result in increased engine wear. There is a reason why GM engineers established this viscosity for these engines. Unless you have extensive research, don't mess with it.
Old Aug 7, 2013 | 04:25 PM
leadfoot4's Avatar
leadfoot4
......just find an oil with a higher ZDDP content.
Old Aug 7, 2013 | 09:14 PM
bwill03z's Avatar
bwill03z
I never said I thought I needed it.. Just something I was considering for peace of mind. I'll stick with M1 5w30 and leave it alone.
Old Aug 8, 2013 | 08:33 AM
leadfoot4's Avatar
leadfoot4
We understand your need for "peace of mind". We're all looking to protect our cars, so we're beginning to look for oils that have a higher level of ZDPP that the current oils that meet the "SN" spec....
Old Aug 8, 2013 | 08:18 PM
Z06-FIX's Avatar
Z06-FIX
Mobil 1 high milage and 0w-40 are 2 that are higher
Old Aug 10, 2013 | 12:36 AM
strand rider's Avatar
strand rider
Mobil one has an 800 information line, if not on the container ask the 800 operator for the number. Of course, then you miss all the fun.
I agree with the other poster, i reading about LS design, I would not change viscosities unless I was certain I was helping the engine. IN other reading here, it seems the high milage version of Mobil 1 is about the oil that matches the stuff in the engine when the C5 was new. Only important if you run real hard, the new oils are good.
Old Aug 10, 2013 | 03:35 AM
Pumba's Avatar
Pumba
If you want the best protection, both in cold and hot weather, use an oil with a Group V base stock and higher levels of Zinc and Phosphorous.
Answer: Red Line 0W40.
To Quick oil question
Old Aug 10, 2013 | 03:36 AM
Bubbletop409's Avatar
Bubbletop409
Or there are zinc additives available also that blend with all oils currently available.
Old Aug 10, 2013 | 04:25 AM
_r2h's Avatar
_r2h
Or M1 0w40. Redline is good stuff though, really good stuff.
Old Aug 10, 2013 | 07:32 AM
leadfoot4's Avatar
leadfoot4
True, but I don't know if I'd want to be messing with an oil's formulation, especially a syn oil, since I'm no chemist.....But on the other hand, in the family's cars that run on dino oil, I always throw a can of STP in at every oil change. The STP cans now state it has ZDPP as part of its formulation.
