Got my headers and xpipe........install?
How ever there are many that went ahead & used their original header bolts, including my self.
You mentioned that you went catless, so I'm assuming that you have the short by pass piece to put in it's place?
I'm also assuming that you went with the LG 2" X pipe?
You may want to install a new set of exhaust gaskets (where the X pipe meets/joins the cat back that you have on the car.
I would use a new set of steel/metal GM header gaskets (2) for the LS/1 motor.
I'd purchase plenty of heat, sticky wrap on all electrical connectors, wires & lines that are near any part of the headers.
I would also make sure to have on hand some anti seize, air pump line gaskets (2), new plugs & wires & if you can easily get your hands on some heat sox to go over the lower portion of the plug wire (at the plugs ) I'd get them too.
Heavy Duty Tall high quality (racheting type) jack stands (4)
