2001 Radiator Replacement
Old Aug 8, 2013 | 11:12 PM
Choreo's Avatar
Choreo
Default 2001 Radiator Replacement
I am looking at replacing my radiator with a DeWitts. I have an auto-trans.
When I disconnect the trans-cooler lines, will the trans fluid drain out? Will I need to refill at transmission?
Old Aug 9, 2013 | 04:11 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
You will lose the fluid from inside the transmission cooler, in your factory radiator, as well as fluid in the lines from the radiator to the transmission. Definitely check your transmission fluid level after the installation of your DeWitts radiator is complete.
Here's a link for the correct procedure to check the fluid level:
http://forums.corvetteforum.com/c5-t...uid-level.html
Old Aug 9, 2013 | 08:04 PM
Choreo's Avatar
Choreo
Thanks!
Old Aug 9, 2013 | 08:10 PM
Quicksilver Vert 01
Originally Posted by Choreo
Thanks!
Old Aug 9, 2013 | 09:31 PM
Patches's Avatar
Patches
PITA with an A4 but you have a Kwik Lift so it'll be a bit easier than on jack stands. Follow the procedure above and you'll be good to go.
To 2001 Radiator Replacement
