Tunnel Plate
Old Aug 14, 2013 | 10:59 PM
fcable's Avatar
fcable
Default Tunnel Plate
I'm am fixing to install a set of AR Headers. While I have all that out, I was thinking about installing a 1/4" 6061 tunnel plate to make the body a little more rigid. Do this plates really help, or not? Any suggestions would be greatly appreciated. Thanks.
Old Aug 15, 2013 | 12:47 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
I can't see how that could make any difference. If anyone said it make a difference at all, i would be very very skeptical
save your money
Old Aug 15, 2013 | 01:42 AM
Mickeyrx70's Avatar
Mickeyrx70
save your money
I recently installed the Elite Engineering "thermal abs" tunnel plate as part of a long tube header install & can't tell any difference from the stock tunnel plate as for stiffening goes; it may have a heat deflecting àdvantage though.
Old Aug 15, 2013 | 08:35 AM
hamhead's Avatar
hamhead
The only point I see for it is keeping heat down in the cabin. I wouldn't expect any performance increase due to body rigidity or reducing wheel hop.
For what its worth, I run without one and have not experienced any major heat in the console area like some report - I do run no cats however.
Old Aug 15, 2013 | 12:28 PM
Last C5's Avatar
Last C5
I have ceramic coated tunnel plates in both my vert and my Z track car and they do reduce the console/interior heat considerably. I would recommend getting one.
Old Aug 15, 2013 | 03:40 PM
Quick 06's Avatar
Quick 06
Agree, coated tunnel plate keeps temps down in the cabin after long tube installs.
Old Aug 15, 2013 | 11:48 PM
SG Lou's Avatar
SG Lou
That's pretty much the reason I replaced mine as well. Made a world of difference in heat reduction, along with insulating the interior.
Old Aug 17, 2013 | 01:52 AM
striper's Avatar
striper
It might not be that noticeable, but the tunnel is a structural component of the entire frame. The C5 chassis was designed as a convertible first so it would resist twisting with the roof off, however when I had a targa coupe you could definetely feel the difference in the car's rigidity when the roof was removed. So I think the tunnel plate can make a difference in stiffness. Maybe not too much though if you have an FRC but I installed one anyway when I did headers and exhaust. Anything that can contribute positively to the handling and make the entire structure stiffer.
To Tunnel Plate
