02 Z06 Brake Pad ?
Old Jun 30, 2002 | 11:11 AM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default 02 Z06 Brake Pad ?
Any difference between 02 Z06 brake pads and 02 C5 pads ?
Old Jun 30, 2002 | 11:18 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: 02 Z06 Brake Pad ? (Snake Slayer)
not that I am aware of...
vetterdstr :cheers:
Old Jun 30, 2002 | 11:39 AM
gmblack3's Avatar
gmblack3
Default Re: 02 Z06 Brake Pad ? (vetterdstr)
12530681 y07-67 standard oem pads front for the 01 Z06.
88952008 y37 standard oem pads front for the 02 Z06.
Not sure what the Part # is for the stock coupe 01 or 02 pads.
You can email http://www.gmpartsdirect. com with your VIN# and they will give you the correct part # for your car. That way you can tell if they are different.
Old Jul 1, 2002 | 12:22 AM
MelloYellow's Avatar
MelloYellow
Default Re: 02 Z06 Brake Pad ? (gmblack3)
Ya, the '02 Z06 are different. But only the Fronts are different, not the rears.
I was going to try them, but put on the PFC Z's instead. I'm very happy with the Z's.
Old Jul 1, 2002 | 01:11 AM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Default Re: 02 Z06 Brake Pad ? (MelloYellow)
I just replaced my front pads with the 02 Z06 pads and so far, I can't tell any differences in stopping distance.
I replaced them because they started to make squeaky noises. But the old pads still has bout 40% left.
:cheers:
-Tuan
To 02 Z06 Brake Pad ?
