TPS wont program
Old Aug 19, 2013 | 12:55 PM
Yellow74c3's Avatar
Yellow74c3
Default TPS wont program
I replaced one of my TPS today (rt rear) and should of checked it prior to mounting it....I didn't....now mounted it doesn't program with the DIC using a magnet, I get the left front ok then the rt front ok then the rt rear doesn't program, was there anything I should have done to the TPS before mounting? The TPS is a Schrader #28006 that I got thru Amazon new....is it not the correct one or? Thanks for any help....Fred
Old Aug 19, 2013 | 01:32 PM
65GGvert's Avatar
65GGvert
What year is your car? What year does the Schrader replace? That would be a starting point. 01-04 sensors are different from prior sensors.
Old Aug 19, 2013 | 02:06 PM
Yellow74c3's Avatar
Yellow74c3
Mine is a 1998....appears to be the correct one...looking to verify that now....Fred
Old Aug 19, 2013 | 03:52 PM
Yellow74c3's Avatar
Yellow74c3
Went to Discount Tire....they used their round magnet....it worked! all set, my angle type welding magnet apparently wasn't strong enough, yes it worked on 3 out of 4 sensors but the new Schrader needed that one Discount used, also they did it for free! Thanks Discount Tire! Fred
To TPS wont program
