new harmonic balancer wobble
Old Aug 23, 2013 | 05:08 AM
sccs's Avatar
sccs
Default new harmonic balancer wobble
i'm almost 100% balancer didint have a wobble when first started..
this is the harmonic balancer i ordered:
DORMAN 594115
Double Serpentine Belt; Diameter; 7-17/32"; Width: 2-27/32"; Weight (lbs.): 11.0
Alternate/OEM Part Number(s): 12553474, 12560115
before the old balancer didnt have any problems
what can be the causes
corvette c5 1998 coupe manual
Old Aug 23, 2013 | 10:34 AM
3boystoys's Avatar
3boystoys
SO, if the old one had no problem why did you change it?
Old Aug 23, 2013 | 04:40 PM
sccs's Avatar
sccs
http://forums.corvetteforum.com/c5-t...ncer-worn.html
Thats why.
Old Aug 24, 2013 | 08:06 AM
vettenuts's Avatar
vettenuts
Is it just a little wobble or a lot? I would contact the vendor and ask about warranty and return. Usually Dorman parts have a warranty.
If you don't get anywhere with the vendor, contact Dorman directly.
Old Aug 24, 2013 | 12:46 PM
sccs's Avatar
sccs
a very small bit,.. is it possible that it would not be balanced good enough on the crank?.. bolt was tightened with an big extantion and with locktite... but though..
Old Aug 24, 2013 | 01:04 PM
lionelhutz's Avatar
lionelhutz
Is this "wobble" visible when you look at the grooves the belt runs in? If you're looking at the outside or front of the balancer then you're doing it wrong.
Old Aug 24, 2013 | 01:37 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Better question...how did you draw the new damper on to the crank?
Old Aug 24, 2013 | 08:27 PM
sccs's Avatar
sccs
well.. the outside of the balancer
with bolt
Old Aug 24, 2013 | 09:22 PM
Chicago1's Avatar
Chicago1
^ That's a nono
http://forums.corvetteforum.com/c5-t...er-how-to.html
Old Aug 25, 2013 | 03:25 AM
sccs's Avatar
sccs
shet. and what now... is it possible i damaged anything?(but i dont belive..) or the balancer isn't well seated?
Old Aug 25, 2013 | 08:27 AM
leadfoot4's Avatar
leadfoot4
If the bolt tightened up without any sign of the threads stripping, the crank, which is the IMPORTANT component, is probably OK. However, you may not have the pulley seated properly on the crank, in which case, as much as it will pain you, you'll need to go back and re-do the installation, following the procedure that "vettenuts" covered in the topic that "Chicago1" linked in the previous post.
Old Aug 26, 2013 | 10:26 AM
3boystoys's Avatar
3boystoys
But you said your old one had no problems.
Old Aug 27, 2013 | 06:06 AM
sccs's Avatar
sccs
No wobbling problem.
To new harmonic balancer wobble
