X pipe
Old Aug 24, 2013 | 08:24 AM
tentuna's Avatar
tentuna
Default X pipe
Does any vendor sell an "X Pipe" for use with stock cats and with a slip fit over the stock pipe and not a butt joint, thinking about this for a winter project? What I was thinking is to cut the stock pipes after the 2nd oxygen sensor and adding the "X Pipe" in that area.
Old Aug 25, 2013 | 10:53 AM
NukeC5's Avatar
NukeC5
I had an x from a local muffler shop welded in. Might go to a shop and see what they have. It was the right size, but without any of the slip fit extras.
Old Aug 25, 2013 | 11:25 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
yes, there is an X-pipe made just for the C5 and it's an easy install. You can usually rent a chain pipe cutter from most auto parts store like Auto Zone.
Here is what they look like http://www.ebay.com/itm/Magnaflow-Ex...-/180858745230
one thing I would add is to use good quality band clamps and not the cheap standard muffler clamps.
To X pipe
