Question about overheating
Old Aug 25, 2013 | 10:52 PM
jrprich's Avatar
jrprich
Default Question about overheating
Yesterday my C5 temp hit 264 and the DIC sent up a warning along with a chime and a red light on the speedo face. Odd since I am in Oregon and the air temp was only about 72F. I was in light traffic.
I have had my 99 C5 since 08 and have put about 60k on her including many trips down south, Vegas, New Mexico, Arizona, Texas, Louisiana in 100+ weather and this has never happened before....not even close. The water pump, thermostat, hoses, belts and coolant were all changed with Delco parts in 2011, about 18k ago.
After reading many posts about C5 overheating on CF yesterday, this morning I pulled the CAI and radiator shroud and pressure washed the radiator and condenser, checked the coolant, both hoses.....all seems fine. Took her out for a two hour drive on twisty roads and a 2k altitude change. She ran at 205-209 with top temp of 212 lugging up an incline most of the time with the AC running. But the temps today barely broke 70 with light rain.....hardly a good heat test.
I didn't burp it as the coolant system has not been opened up since 2011 so I don't see why it would develop an air bubble yesterday.
Thoughts or suggestions?
Thanks,
Jim
Old Aug 26, 2013 | 01:56 AM
Old Horsepower's Avatar
Old Horsepower
"Yesterday my C5 temp hit 264 "
I wonder how hot the oil was? It might be a good idea to change it soon.
Old Aug 26, 2013 | 08:15 AM
runner140*'s Avatar
runner140*
Mine hit that once (I tossed a belt), changed oil/filter/coolant/
and of course, a new belt.
Old Aug 26, 2013 | 10:31 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
bad/weak secondary fan???
how hot will get while sitting still idling with AC on?
Old Aug 26, 2013 | 10:52 AM
will2045's Avatar
will2045
I would still burp the system I didn't open my system for years and it developed massive air bubbles and did the exact same thing. These system are known for issues like that. its easy just grab the tiny hose in the top of the rad that connects to below the TB. off with the clamp pull the hose. open the reservoir (after making sure it has plenty of fluid and i would be completely shocked if it didn't have air. I don't know why they randomly aquire air over time but they tend to. both my c5 and my buddies c6 did the exact same thing.
Old Aug 26, 2013 | 01:08 PM
jrprich's Avatar
jrprich
Thanks guys,
So this AM I burped it from the left head location, let about a quart come out. Didn't hear any air but it is now done. The upper hose was not sucked together in the center. Also got a new cap and topped off the tank with fresh 50/50 Dexcool.
I checked the fans yesterday and they both turn on when they are supposed to and will go to high with the AC on. The oil was just changed about 1k ago with Mobil 1 and it looks and smells fine.
Will drive her today, as usual, as she is a DD and see what happens now as temps will only be in the high 60s, low 70s with chance of rain ;^( .Guess our Oregon summer is over......it was a nice one this year.
Thanks again,
Jim
Old Aug 26, 2013 | 03:20 PM
pewter99's Avatar
pewter99
even though the fans come on they may still not run at full speed....BTDT with my girlfriends 02...somewhere there is a post in how to check them
Old Aug 26, 2013 | 05:53 PM
jrprich's Avatar
jrprich
Well I just got back from about 2 hours of driving a mix of surface streets and freeway.
From overnight cold to 200d took 5 minutes at about 20-45 mph non stop driving with an outside temp of 72d with the AC on. Driving around town w/AC temps stayed in the 205-208 range...pretty much the same as yesterday's drive so the burp didn't seem to change things.
Is 205-209 w/AC abnormal for a C5 with 89k on it?
Jim
Old Aug 26, 2013 | 07:13 PM
jrprich's Avatar
jrprich
I just spent about an hour searching........no luck so far.
Old Aug 27, 2013 | 07:00 AM
pewter99's Avatar
pewter99
here Doug posted in my Maggie IC relocate thread http://forums.corvetteforum.com/1584193221-post41.html
I knew I saw it somewhere....says he hooked up a switch to figure it out...may need to ask him if thats something you want to pursue
Old Aug 27, 2013 | 12:04 PM
jrprich's Avatar
jrprich
Thanks for the info
To Question about overheating
