new timing chain?
Old Aug 29, 2013 | 02:02 PM
xomega's Avatar
xomega
Default new timing chain?
went by the local gm dealer to pick up a timing chain for my ls1, I got home and noticed the part number looked funny....gm PN 12646386
I google it... says 2014 series lt series, which appears to be in the 2014 corvettes... anyone have any idea on compatibility? I guess I could return it.. thanks!
Old Aug 30, 2013 | 05:20 PM
xomega's Avatar
xomega
went back today, they verified that in fact. this is the new chain off the gen V block, and that this was the new chain for ls2. that the ls2 chain crossed over to this. he said it was in there parts system, but not out in the catalogs yet.
Old Aug 30, 2013 | 08:03 PM
Rx7Rob's Avatar
Rx7Rob
I installed the LS2 chain (12586482) in my 2000 LS1
Old Aug 31, 2013 | 09:34 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Went Ls2 chain when we swapped to my new cam!
Old Sep 1, 2013 | 04:18 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Me too!
I just finished putting my '01 coupe back together yesterday, after installing an ATI damper on it. Figured since I had it down that far, I might as well as throw a new chain on it too....
Old Sep 11, 2013 | 11:09 PM
SaberD's Avatar
SaberD
Did you ever install the LT1 chain? Everything work out ok? Need to buy a new chain and wondering if I should go with the LT1 or LS2.
Old Sep 13, 2013 | 12:29 PM
MT0911's Avatar
MT0911
LS2 chains work fine and are actually more heavy duty then the stock LS1 chains so you should be in good shape
Old Oct 24, 2013 | 02:05 PM
c2vette64's Avatar
c2vette64
Except that if you go to order the 12586482 LS2 chain from a GM dealer they show it superseded by a new part number which is the same (dimensionally anyway) as the "lighter duty" LS chain. They also show no inventory on the 12586482 chain. No idea how the new LT1 compares, but obviously you could just compare the thickness of the chain links.
Old Oct 24, 2013 | 04:02 PM
vettenuts's Avatar
vettenuts
If it supercedes the LS2 chain then just run it or go aftermarket. GM does this all the time. It is a better chain then your car got delivered with.
To new timing chain?
