I have dash lights when the key is in the ON position but go out when the engine is running at night. (lights are on) dimmer switch doesn't help, whats wrong?
Check your tail lights too - if they are out when the headlights are on, it is probably your headlight/ directional switch. This seems to be a common issue. Fortunately, this is a free fix:
thanks, I checked, no tail lights either. the headlight/ directional switch
was replaced a year ago. all works in the twilite mode. time for another switch i guess, thanks again.
