air bubbles in heater core
Old Aug 31, 2013 | 07:59 PM
philip pugliese's Avatar
philip pugliese
Cruising
Default air bubbles in heater core
I guess im sold that my 2001 vert has air bubbles trapped in heater core from this bubbling noise coming from drivers side dash. Does anybody have a solution to get rid of these bubbles because the noise is driving me crazy or will they work themselves out eventually. I tried burping the system as per the service manual but no luck. And why does the noise totally disappear sometimes. If there is air trapped in there wouldnt it make that bubbling noise all the time?
Old Aug 31, 2013 | 10:00 PM
LoneStarFRC's Avatar
LoneStarFRC
I think you're hearing AC refrigerant, not coolant.
Old Sep 1, 2013 | 09:26 AM
philip pugliese
Cruising
I thought A/C refrigerant was a gas. If it is a/c refrigerant how do you get rid of the bubbling sound?
Old Sep 1, 2013 | 09:53 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I find it difficult to believe that there is air trapped in the heater coolant system.
If you turn the HVAC FAN off does the noise go away?
I find it more plausible that you are hearing the fan touch condensation that is trapped in the air box.
If thats what it is, you have a drain that is clogged up on the fire wall. Run the system with the HVAC fan OFF and see if the noise goes away.
If you do fine that you have condensate built up, make sure that you do not have wet passengers side carpets and a wet BCM
BC
Old Sep 1, 2013 | 11:31 AM
philip pugliese
Cruising
I hear the noise everytime on start up without putting the a/c or heat on. It appears the same whether i use heat and air or not. As far as the clogged drains i did just clear out the 3 that are together on drivers side firewall. The noise is coming from what i can hear right behind speedodometer in dash. Very weird. It comes and goes but always there on start up.
Old Sep 1, 2013 | 11:32 AM
philip pugliese
Cruising
As far as passenger side floor it is bone dry. Just had to put an LMC5 in last week.
Old Sep 1, 2013 | 12:34 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ok,, lets go on this theory.. If there is any air in the system, it would have to be caused by:
1, No pressure in the system allowing steam to collect in the lines
2. Head gasket leak.
3. Low coolant level in the reservoir tank
Make sure that the tank is properly filled, make sure that the system is properly pressurized. Theres a newer style cap with a higher pressure rating. Recommending upgrading.
Check the antifreeze for exhaust gasses. Auto parts sell the test kits.
Old Sep 1, 2013 | 02:21 PM
philip pugliese
Cruising
I think I'm good with everything you mentioned. Just recently had a new water pump put in and I've already upgraded the coolant cap. What are signs of head gasket going? And do any coolant hoses route by speedometer? I thought the heater core hoses were mostly located on passenger side.
Old Sep 1, 2013 | 02:26 PM
philip pugliese
Cruising
And i think you were right on a possible HVAC condensation problem. If they is air trapped somewhere in coolant system wouldnt the car run hot? My temps are pretty much right on approx 195 degrees when driving
Old Sep 1, 2013 | 02:52 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,, here are some pictures for you and yes,, the AC and Coolant openings are on the drivers side. Heres a picture from the inside out:
Old Sep 1, 2013 | 03:37 PM
LoneStarFRC
Depends on it's temperature/pressure, etc. Refrigerant constantly changes states from gas to liquid as it circulates through the system.
Have an HVAC tech check your system pressures, etc.
Old Sep 1, 2013 | 04:28 PM
philip pugliese
Cruising
Thanks for all the help guys. Just going to leave the car with my mechanic because as luck would have it the two times I drove it there so he could hear the noise it stopped.
Old Sep 1, 2013 | 05:48 PM
Paul 75 L82's Avatar
Paul 75 L82
Bill, that's one hell of a picture.
Old Sep 1, 2013 | 07:17 PM
Zorlac's Avatar
Zorlac
Ain't it though. I have quit a library thanks to Bill.
Old Sep 1, 2013 | 07:31 PM
LoneStarFRC
I remember seeing it when I visited the Corvette Museum in '99. You can tell it's a '97 (or '98) in that pic by the two fuel lines. I would think '97. GM did a nice job.
Old Sep 1, 2013 | 09:16 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are several rolling display chassis. The one pictured earlier was at Carlisle PA.
Here is the one at Bowling Green
To air bubbles in heater core
