I got borla stingers catback with lg pro long tubes and a vararam. I haven't tuned it yet I'm going to do that next month. But I just wanted to know with tires and good seat time can I hit an 11????
What do you experts think
If by "tires" you are referring to real drag tires like MT ET streets or the like, then yes, that is a possibility (With the tune). Some people need gears to get there if the bolt on's aren't enough though.
DR stands for drag radials. You dont usually want radials. Get an actual bias-ply racing tire. You get the ripple effect from the soft sidewall and and better grip in most any case.
I have heard that auto's do well with radials though.. which transmission do you have?
I'm assuming you are talking about slicks? I have the stock tranny with a m6
Good driving is more important than anything. Member Ranger ran 11s with a bone stock Z, tires and all. Assuming you already have 3:42s, with tune and tires, I believe your car is capable of 11s.
Street slicks or slicks are great. I use the MT ET Street tires I mentioned before. They are not a full slick and are a DOT approved tire. Not that they are a good street tire. But they are a great drag tire that you can drive on for a few days till you get around to changing them. I did a pfadt solid transmission mount and have never had wheel hop running these tires. My trans is stock and Im pushing 400 wheel and launching at 3k ish rpm. As long as you get rid of the violent wheel hop, using slicks shouldn't be to much for the stock drive train to handle.
I have a feeling you are going to have a very hard time hitting 11's with a non z, the biggest factor is how well you can drive your car. Heck I was only able to get 12.36 out of my z which has intake, exhaust, tune and a little bit of weight savings with DR's. Now given that was my first time out and Im not the best driver at any means but Id say Im about average maybe a little better than average.
