MAF Broken- Need Help
Old Sep 5, 2013 | 11:21 PM
outlawtubbywales's Avatar
outlawtubbywales
Default MAF Broken- Need Help
Hey guys- had my 02 Z for a couple of weeks and installed my VaraRam tonight. The AC condenser and radiator were packed with grass, sticks, dirt, plastic bags and some other crap. But my main concern is the MAF. The plastic side of housing is cracked where it slides in the hose and the broken portion has to be blocking airflow.
I guess I need to buy another one- any suggestions on OEM vs aftermarket? I have the CAI and plan on long tubes and cat back exhaust. Does the mass air flow sensor have much affect on power and or fuel consumption ??
Old Sep 5, 2013 | 11:23 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
stock is fine
Old Sep 6, 2013 | 06:34 AM
WKMCD's Avatar
WKMCD
DO NOT even consider the Granitelli MAF. There a benches all over the world where they're being used as paperweights.
Go stock which is fine.
Old Sep 6, 2013 | 08:01 AM
Cybermind's Avatar
Cybermind
I'll go even further and say; do not even consider any aftermarket MAF. Make sure you buy the stock OEM MAF for your year and model of car.
Old Sep 6, 2013 | 09:18 AM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
I'll have one available after this weekend if you're interested. I'm swapping mine out for a LPE 100mm to fit my new setup.
Old Sep 6, 2013 | 06:36 PM
outlawtubbywales
Thanks for the replies- OEM sensor on the way.
Maxx_Z06- i would hit you up, if I would have known earlier.
Old Sep 6, 2013 | 08:13 PM
RedZMonte's Avatar
RedZMonte
Good time for a Haltech Screen (or simmilar) if the maf sreen has been removed.
S
To MAF Broken- Need Help
