After header install, miss developed...
Seems to begin during right turn, and clears up under full throttle until throttle is reduced for next turn. When idling in off track there's a terrible miss. When things cool off, it good to go again until it gets hot.
I replaced the spark plugs and wires.
Any ideas?
What plugs/wires did you use? (Brand, type (plat, copper, irridium) and temp of plugs) Did you gap them (some plugs are supposed not to be gapped). If you have a scan tool you can scan to see if its a miss and what cyl has the miss. Did you use plug wire grease between the plugs and wires and did you check the connections between the wires, plugs and coils? did you try the old wires on the car and see if it changes?
S
Some times the new boots will cause (trapped) air to eventually pull the wire away from where they make connect onto the coil, not making a proper/direct contact.
Also when the 02 sensor wires get crossed, it will create a pronounced miss at all levels of RPM.
That's when I shrugged.
It only misses when coming off throttle and when the engine is hot (after a few hot laps). When I go back to full throttle the miss goes away, but after it's occurred, it stumbles bad at idle.
After it's cooled down, it's good to go, again.
Tune didn't make any difference. Miss was there before and after.
New GM Performance (the red ones) plug wires. I have the nomex boots over the ends.
I checked the resistance on all the new wires before installation.
I installed the new wires because I suspected the old wire as being the problem, but the same issue returned.
I'm thinking it might be a coil, since most other electrics have been eliminated, but since I don't want to buy 8, I'll have to get the engine to the temp to create the miss (it's a race car so on the street doesn't work), and change each coil to a new one until it doesn't miss.
Getting it to temp is the hard part.
It's the relationship to hard throttle application that's making me think in this direction.
HTH
The harness on the drivers side of the intake manifold is known to rub thru near the back of the fuel rail. on the black bracket behind the fuel rail.
BC
BC
Thanks!
BTW, engine is a H/C/H setup and moved to Champion copper plugs in one colder heat range. Have worked excellent and do last many miles in my daily driver. Reduce gap to .035 and you are good to go. Oh, and the best part is they are sold at Kragen's for under two bucks each! Trust this is helpful...
A1
