Friends 2001 automatic coupe has a LOUD whining/growl noise at any speed during coast or very light throttle. Diminishes on accel or decel. All the fluids look good, just started suddenly. Only has 28000 miles on it. Any common things to look for? Differential failure common?
Thanks,
JB
Differential bearings, especially the right side bearing damaged. Gear oil looked good but the magnet in the bottom of the case was LOADED with metal powder. Installed a used differential and sounds good now.
Just thought this might be of help to others.
JB
