same size tire all 4 corners
Old Sep 14, 2013 | 12:48 PM
Apocolipse's Avatar
Apocolipse
Default same size tire all 4 corners
Hey everyone,
Was curious if anyone knows how the C5 handles when you run the same tire on all 4 corners.
The way its set up stock suggests that it would push in corners due to a smaller footprint in the front and wider in the rear. However, the springrate suggests that gm stiffened the rear to help the *** end slide out more in a turn (a component of weight transfer due to roll stiffness)
So what's the dealio?
Old Sep 14, 2013 | 03:41 PM
Last C5's Avatar
Last C5
You will definitely have to turn the traction control off or you won't get far. I ran a set of Pirelli Trofeos in a square set up the first time, 295/30/18s and I expected the tail to get a little happy, but it didn't happen. The car turned in better and the tail was as solid as ever. Since then I've run a set of Hoosier square with the same result - better handling. If I go back to my standard Toyo 888s it's going to be a 315/30 square set up. I am running a track alignment and heavier bars.
Old Sep 14, 2013 | 08:26 PM
Apocolipse's Avatar
Apocolipse
TC? Who uses TC anyways? Isn't TC supposed to be the driver?
Negate the effects of the tc... What about the actual handling dynamics of the car. Its a 50/50 weight distrobution but front and rear have different roll stiffnesses. Now put the same rubbers on... What's that give you.
I'm not a fan of staggered. Thanks for the experience post about your different rubber setups. I have the z51 suspension parts and looking at bilstein or z06 shocks to help out a bit. Might go up on the sway bar stiffness too...
Old Sep 15, 2013 | 01:54 AM
getkong's Avatar
getkong
I have 295/35-18 on all four corners, and have no traction control issues. Seems to work just fine. The fronts have a couple thousand more miles on them, but that's it.
Old Sep 15, 2013 | 10:23 AM
Apocolipse's Avatar
Apocolipse
How's she handle? More neutral? What suspension?
Old Sep 15, 2013 | 07:50 PM
guido7834's Avatar
guido7834
But I think it looks like crap...
Old Sep 15, 2013 | 08:55 PM
Apocolipse's Avatar
Apocolipse
Function > form.
Old Sep 16, 2013 | 02:43 PM
getkong's Avatar
getkong
Not much different for street driving, but i haven't done a track day yet. Signed up for one in November, so i can let you know afterwards.
Old Sep 16, 2013 | 06:00 PM
Apocolipse's Avatar
Apocolipse
That would be great thank you.
I have the z51 package on the C5. Been thinking about upgrading sway bars to a z51 C6...or z06 C6... Difference is the z06 has a stiffer rear and same front.
Typically that would cause the *** end to come out more when its stiffer. Maybe due to the z06 having wider rears to compensate?
Old Sep 17, 2013 | 10:58 AM
Corvette_Ed's Avatar
Corvette_Ed
If you have less than 305 width rear tires it is not recommended that you use the Z06 sways, but instead use the Z51's.
Old Sep 17, 2013 | 03:49 PM
Apocolipse's Avatar
Apocolipse
Due to too much weight transfer causing the rear to slide out easier? Now... If it were 305 on all 4 corners still the same game?
Old Sep 18, 2013 | 09:58 AM
RDnomorecobra's Avatar
RDnomorecobra
on the street it's likely that the only thing you will notice is that the front end tends to "hunt" over grooves more. on the track running square makes the car more neutral by taking out some understeer. I have run 295/35, 305/35, 315/30 on track all with similar overall effect. I have never had an issue with TC/AH. some do some don't. not sure why. mine is a '03z.
Old Sep 18, 2013 | 11:25 AM
Apocolipse's Avatar
Apocolipse
Which sways/springs are you running to make it more neutral? Would staying with my c5 z51 springs + c6 z51 sways be more neutral with square tires vs c5 z51 springs and c6 z06 sways?
Old Sep 18, 2013 | 01:51 PM
RDnomorecobra
I personally am running c6 z51 bars. the stock bars were rusted at the bushings when I bought my car so I bought these. it was before I started tracking the car more seriously, I am likely going to put T1 bars on soon.
this is the general opinion I've picked up in the roadracing forum and my experience is similiar ... regardless of which sways you have, if you leave everything else the same and just go square tire setup, the extra grip in the front tends to reduce the understeer in the car. a stock c5z off the showroom understeers a bit, most stock street cars do .. its a safer set up. The car feels very neutral and predictable with 315/30's at all 4 corners on 4 18"x10.5" stock rear wheels. Again, I don't think you can push the car enough on the street to really notice it.
Old Sep 18, 2013 | 03:31 PM
Apocolipse's Avatar
Apocolipse
That is very good information I do really appreciate that. Off the floor they always understeer due to being easier for the average cusotmer to recover when loosing control.
What springs are you running in your setup? They would make a difference in sway choice and keeping balance. I just want to make sure I'm not wasting my $ and time if someone else has the same experience.
It sounds like the c6 z51 are better than the z06 bars for keeping balance I may just go that route like you did. So that would be z51 springs from c5 and z51 for sways out of a c6.... Then run 305 on all 4.
Hopefully would keep it neutral and handle great. What shocks are you running to keep damping under control?
Old Sep 18, 2013 | 04:02 PM
RDnomorecobra
I have stock springs and upgraded to '04 z06 shocks. The c6 z51 sways are a bit stiffer than c5 z06 but not by much.
Old Sep 18, 2013 | 04:16 PM
Corvette_Ed
Make sure you get the 2013 end links to replace your stock links when you order the sways.
To same size tire all 4 corners
Old Sep 18, 2013 | 10:33 PM
Apocolipse's Avatar
Apocolipse
Those the full metal ones?
I really appreciate the help you guys. I promise ill give back as much as I'm getting with this forum!!
Z06 or bilsteins? I've heard good things about them.
Rd... If your upgrading to T1... Wana sell ur old sways? Send me a pm sir.
Old Sep 19, 2013 | 12:10 AM
Last C5's Avatar
Last C5
Put the tires on first, see how it handles, then buy different sways only if you need them. Don't fix problems you only think you might have. I run Hotchkiss bars with the rears set on the outside holes making it less stiff than stock C5Z bars. The cars handling is totally neutral. Track set up is a slow one item at a time process. Good luck and have fun.
Old Sep 19, 2013 | 10:07 AM
Corvette_Ed
The upgraded version of them, yes.
