C5 Differential Rebuild
Old Sep 15, 2013 | 07:43 PM
spedaleden's Avatar
spedaleden
Default C5 Differential Rebuild
My sons differential started leaking and he has gear noise, so we decided to pull the differential and change the Ring & Pinion to a 3:73 ratio. Decided to use Motive Gear for ring & pinion and going to take diff to my friend to rebuild. Just wondering if its cheaper to buy a diff done by one of the vendors.
Any help is appreciated
Old Sep 15, 2013 | 08:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You do know,,,,,, who ever rebuilds your rearend,,, has to have a KENT MOORE C5/C6 Differential Alignment tool,,,, Correct????
You do know,,,,,, you can upgrade your rear with C6 parts?? Here are a few post for you. This is the MOST cost effective way to bullet proof your rear.
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Examine the post provided and order the C6 GM parts from Gene Culley or Patrick at www.gmpartshouse.com
If you need a real professional rebuild,, Call Rick Kim
RKT-56
RKT56
http://rkt56.com
Phone number: 301-257-0930
205 Bucheimer Road, #C
Frederick, MD 21701
You will NOT be disappointed!!!!!!!!!!!
Old Sep 15, 2013 | 08:29 PM
Bob Chapman's Avatar
Bob Chapman
I would check with Rick at RKT56.com He is in Fredrick Maryland and he does good work.
Old Sep 15, 2013 | 08:52 PM
Apocolipse's Avatar
Apocolipse
Shop press, pickle fork, and torque wrench.
Old Sep 15, 2013 | 10:16 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL I have excellent mechanical skills BUT,,,,,,,,,, Some people dont,,, Thats why I recommend RICK!!!!!!!!!!!!!!!!
BC
Old Sep 15, 2013 | 10:37 PM
Apocolipse's Avatar
Apocolipse
Haha yeah that is very true. 99% of the time that's the best option.
Old Sep 16, 2013 | 02:10 AM
zeevette's Avatar
zeevette
That's what I did. Super good guy to work with, and no noise or leaking. I recommend a ECS trans brace that will eliminate a lot of the stress on the diff.
Old Sep 16, 2013 | 03:23 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
RKT-56
RKT56
http://rkt56.com
Frederick, MD 21701
BC
Thanks Bill!
Thanks Bob!
Not quite but close. LOL
Thanks Dave!
Give us a call, we have exchange programs to save you time but we can also rebuild your units. 2-3 day turn around.
__________________
Old Sep 16, 2013 | 06:02 PM
Apocolipse's Avatar
Apocolipse
Biggest thing to do is to take your time and keep the area CLEAN.
Most people CAN do it but only a few can do it right without noise.
Old Sep 16, 2013 | 07:06 PM
lsxvette's Avatar
lsxvette
rick r u any where near jim justice?
Old Sep 16, 2013 | 08:42 PM
SaberD's Avatar
SaberD
It's less to buy it from a vendor since you need to buy the tools (around 350 or 400 if you can find a good deal), 2 sets of carrier shims, and a set of pinion shims. (total around $350 from dealer for shims) I had fun doing mine though, and now I can do it again if I ever need to. I like having the piece of mind that I do all my own work as well.
Old Sep 16, 2013 | 08:52 PM
spedaleden's Avatar
spedaleden
My son ordered ring & pinion from Motive. I used Motive on my C3 and love it, no noise. My buddy doesn't have the tools but his friend works at Black Dog Racing by us and they set up any year Corvettes for racing, so his friend said no problem piece of cake, should have it back by Monday and taking it to him on Friday.
Thanks for the help
Old Sep 16, 2013 | 08:54 PM
spedaleden's Avatar
spedaleden
Originally Posted by Rick@RKT56
Thanks Bob!
Thanks Dave!
Thanks for all of your information
Old Sep 17, 2013 | 10:38 AM
Supporting Vendor
I'm sorry but I don't know Jim Justice. We are located in Frederick, MD.
Old Sep 17, 2013 | 09:54 PM
spedaleden's Avatar
spedaleden
Cleaning things up to put back together, waiting for ring & pinion to send out diff for overhaul.
Old Oct 5, 2013 | 03:56 PM
spedaleden's Avatar
spedaleden
Rear differental was rebuilt with motive gears (3.73) car is back together and all is good. No whine and my son really likes the new ratio. Had to buy plastic clips for rear brake lines that attach to rear cradle, GM bent us over on those but otherwise not that bad of a job.
Old Oct 5, 2013 | 05:09 PM
Apocolipse's Avatar
Apocolipse
Plastic clips? You mean zip ties? Lol
Old Oct 5, 2013 | 08:11 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The brake lines are secured and isolated on the K member with little plastic keepers. They snap onto the K member with a Christmas tree stems
Yes,,,, GM will rape you for each one!
BC
Old Oct 21, 2013 | 09:31 PM
lsxvette's Avatar
lsxvette
niccce
To C5 Differential Rebuild
