Issues after Battery died
Old Sep 17, 2013 | 12:35 PM
Wigglett's Avatar
Wigglett
Default Issues after Battery died
The car sat for 6 months went to start it and it was dead ! Charged battery ,the vehicle started and runs great ,but the active handling light and ABS light are on ,yes the battery is an optima .we checked codes the 1518 code came and went (probably due to the dead battery )Read through Bills electrical thread and will start checking all the grounds .Any thoughts or suggestions
Old Sep 17, 2013 | 12:49 PM
Paul 75 L82's Avatar
Paul 75 L82
Maybe it just needs to be drove a little.
Old Sep 17, 2013 | 01:12 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CLEAR ALL THE DTCs!
Start and drive the car and if and when the EBTCM codes and messages come on...... WITHOUT turning off the ignition,, pull up and read the DTCs!
Report what comes up!
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine. NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Old Sep 17, 2013 | 04:08 PM
Wigglett's Avatar
Wigglett
Bill thanks in advance
Here are the codes that came up
28-TCS no comm
58-SDM -U1040
10-PCM-1571
38- RTD C0710
This is so strange the car was fine prior to it sitting ?
Old Sep 18, 2013 | 12:45 PM
Wigglett's Avatar
Wigglett
I cleared the 4 codes that came up and they came right back not sure where to start
Old Sep 18, 2013 | 06:21 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check power and ground first.. Check fuses WITH A METER and make sure that the fuse is good and you actually have the correct voltages
Under Hood fuse box Fuse 52 & 5
Instrument Panel Fuse Box Fuse 8
Inspect the main connector on the EBTCM and m,ake sure that it is on tight and not damaged.
BC
Old Sep 19, 2013 | 09:00 AM
Wigglett's Avatar
Wigglett
Thanks for the help battery voltage is 12.2 any recommendations on batteries ,this is the second optima POS
Old Mar 10, 2014 | 12:32 AM
Wigglett's Avatar
Wigglett
It's been awhile since I have posted but my problem still exists same codes I have checked all fuses and voltage .what should I do next
To Issues after Battery died
