Ignition Switch Removal Question
Old Sep 21, 2013 | 10:19 AM
dadaroo's Avatar
dadaroo
Default Ignition Switch Removal Question
I plan to replace my ignition switch. In the FSM it says to first remove the lock cylinder electrical connector. Then, there is an IMPORTANT note for once you have removed the lock cylinder. It says to note how the lock cylinder wire is wrapped around the base of the switch bezel.
Can someone clarify this so I don't screw it up (or try to keep me from screwing it up). I am not sure why this is shown as an important note.
Thanks, Mr. Sam
Old Sep 21, 2013 | 12:37 PM
tacman's Avatar
tacman
St. Jude Donor '13
Can't tell you why its important, but as you carefully remove the lock bezel, you will see a black wire attached that circles the ignition cylinder. Just re-assemble the same way.
Old Sep 21, 2013 | 02:16 PM
corvettebob1's Avatar
corvettebob1
It's important because it's the wire that goes to the BCM for reading your key resistance.
It's also very tiny wire and any excessive flexing will break the strands leaving you stranded.
Old Sep 22, 2013 | 08:36 AM
dadaroo's Avatar
dadaroo
Thanks guys, I'll try not to screw it up too much.
Old Sep 24, 2013 | 09:00 AM
MT0911's Avatar
MT0911
Check this out - Bill has a pretty detailed writeup on removal, very helpful.
http://forums.corvetteforum.com/c5-t...ch-repair.html
Old Sep 24, 2013 | 10:53 AM
dadaroo's Avatar
dadaroo
Thanks also MT0911.
Old Sep 24, 2013 | 12:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by corvettebob1
it's important because it's the wire that goes to the bcm for reading your key resistance.
100% correct!
To Ignition Switch Removal Question
