Need Help With Bad Engine Or Transmission Behavior
Old Sep 21, 2013 | 04:29 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Default Need Help With Bad Engine Or Transmission Behavior
Drove down from outside of Philadelphia to Atlantic City this afternoon. After behaving beautifully for a little while, I started to notice what seemed like a transmission slip, mostly at low speeds. It got worse over about 25 miles, disappeared, and than returned intermittently. We got to Atlantic City and pulled into a parking garage. When using reverse, the car began to buck in a fairly scary manner. For the last couple hundred feet it bucked in drive, but less horribly. Parked the car and restarted it just in case - it bucked in park like it had in reverse.
Thoughts?
2003 'vert, A4, very stock, 43k miles
Old Sep 21, 2013 | 04:49 PM
BigGun's Avatar
BigGun
Thoughts?
Sounds like motor to me, especially with the problem in park. Can you describe "buck" a little better. You can pull codes on your 03 using the dic. Use this method and post all the codes. http://www.stengel.net/diccodes.htm
Old Sep 21, 2013 | 04:51 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Thanks! I will pull the codes tomorrow morning.
One more bit of information - no check engine light. I know that doesn't necessarily mean anything ...
Old Sep 22, 2013 | 07:56 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Short form - it's fixed: thanks for the help. Full report coming ...
Old Sep 22, 2013 | 08:19 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
We got up this morning, checked out of the hotel, and went back to the parking garage. I pulled the codes, but there were no current (non H) codes. Started the car up: bad bucking and stalled a couple of times in idle, though she would move in drive. We parked the car and I told Ivelis (my wife) that I was going to perform a visual inspection of the engine compartment.
I poked around for a minute and than - paydirt. We have a fancy, heavy, and reasonably effective Blackwing air filter. The clamp following the MAF had come almost completely detached over the previous 75 miles, allowing a stream of hot and uncontrolled air into an engine that was believing what the MAF was telling it. I grabbed my geek Swiss Army knife and realigned and re-tightened the clamp. Ivelis restarted the engine and suddenly Grace was back to being her usual wonderful self.
Old Sep 22, 2013 | 11:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
GOOD WORK!!
To Need Help With Bad Engine Or Transmission Behavior
