SmokingI on decel
Old Sep 26, 2013 | 04:59 PM
rttmike's Avatar
rttmike
Default SmokingI on decel
Having a strange issue. The car runs great but if I run it high up in the RPM's driving hard, it smokes a lot on decel while engine braking. It seems to come and go. I do have a home mad catch can in place as well. Any ideas?
Old Sep 26, 2013 | 05:35 PM
Kmcoldcars's Avatar
Kmcoldcars
Smoking on deceleration is usually a sign of bad rings. You may want to do a leakdown test and/or a compression test.
Old Sep 26, 2013 | 07:06 PM
racebum's Avatar
racebum
even a manifold vacuum test would let you know if there is a major compression issue or if the motor is just getting worn
as stated above a leakdown would be best
Old Sep 26, 2013 | 07:56 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Smoking on decel is " Never" a sign of bad rings.. it would smoke on accel as well. the signature of decel only smoking is valve seals.
Old Sep 27, 2013 | 12:44 PM
rttmike's Avatar
rttmike
I planned on doing heads anyway. I wonder if I should just wait for that and hope it's not rings. Car has 92k on it.
Old Sep 27, 2013 | 04:16 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% Nail on the head!
Intake valve seals. Normally replacing the intake & exhaust seals remides the issue BUT, while you are in there, you really should upgrade the springs if they are high mileage springs.
I would also replace the rocker arm trunions to the new improved COMPCAMS Trunions.
My 2 cents
BC
Old Sep 27, 2013 | 04:25 PM
Dennis Wilson's Avatar
Dennis Wilson
To SmokingI on decel
