Turn ignition on and right away it goes into REP and the codes are P1120,P1220,P1514, P11516, P1571. The car cranks but won't start can this be a bad TAC module??? Looks like acid leaked on it. I'm in the process of taking out the TAC module how do i know it's bad is there a teat to preform to determine if it's bad???? These are the codes that keep coming back after resetting code.
A week prior to no start my curise control stopped working. It inguaged but would disinguage a sec later it wouldn't stay ingauged and i noticed my safety bag light indicator is on as well.
If acid got on it then it might just be the connectors. Since acid is a good conductor a good cleaning may fix it if leakage did not get inside and/or a short did not affect the internals. I have read that the 1999-2004 TAC modules are the same and interchange but the 1997 and 1998 are different.
Thank you
I took fender off and checked and cleaned evrything no signs off wire danmage and the connections look like new. I open PCM and there is no signs of leak to the inside. So i guess i'll just order a TAC Module i don't know what esle it can be. Thanks again
I was not at home when I posted. Having now looked at the FSM, I think it is your Throttle Position Sensor. P1120,1220,1514, and 1516 lead me to believe that given I don't have your car in my garage. P1571 is for ASR and is unrelated to your problem in my opinion.
If it were me, without further diagnostics, I would check it's connector and replace it if needed.
Ok update when i first turn on car it goes into REP and TB does not move. When i reset codes TB activates and moves. TPS does not show volts???? Does this mean anything??
Not at home now but will look at the FSM when I do. So we are clear, please clarify "REP" and "TPS" so I am not assuming. Suggest you PM me with your phone number so we can discuss diagnostics better and clarify exactly what the TB does when you go to "Start". Also, what year is your car? I am using a 2001 FSM but I think this design is the same for all C5s. I can confirm with my dealer friend.
