Right turn signal keeps going out
Old Sep 27, 2013 | 01:57 PM
Mew2's Avatar
Mew2
Default Right turn signal keeps going out
Hey guys Ive changed the right turn signal in my car twice now and it went out just now. The first time was a cracked bulb the second was a yellow like thick liquid melted on it. Any ideas?
If it matters I sometimes have to press the emergency light button to get the turn signals to work.
Old Sep 27, 2013 | 02:03 PM
runner140*'s Avatar
runner140*
Never had the "thick liquid melted on it" or a "cracked bulb" but I also have had my right side directional signal bulb blow several times in the last few years.
I purchased several spare bulbs and have an 11" needle nose pliers to do the replace.
Old Sep 27, 2013 | 02:23 PM
Corvette_Ed's Avatar
Corvette_Ed
Normally, when bulbs blow consistently it's a sign of a crack in the DRL housing that is letting moisture in. My suggestion would be to look for a crack, and when found replace the housing with a new one. Another long-term solution is that after replacing the housing go with LED bulbs instead of the standard bulbs. You will need a hyper-flash harness for the turn signals.
Old Sep 27, 2013 | 05:38 PM
avigar's Avatar
avigar
Or, just do the DRL relay mod like I just did recently and save yourself money.
Old Sep 27, 2013 | 07:18 PM
Mew2's Avatar
Mew2
What would that be? Do you have a link to a thread?
Old Sep 27, 2013 | 09:31 PM
lionelhutz's Avatar
lionelhutz
Look for the hole in the housing above the bulb. If there is a hole, you have to fix it or replace the housing. I would recommend LEDs and install a new flasher relay yourself to eliminate the hyperflash.
Old Sep 28, 2013 | 12:40 AM
wcsinx's Avatar
wcsinx
The melted yellow stuff was actually the plastic housing above the bulb. Over time, the bulb heats it up and melts a hole in it. Then once there's a hole, moisture will get in and repeated blow the bulb. Personally I just cut a piece of aluminum tape (the stuff used for assembling dryer ducts, available at Lowes/HD/Ace) slapped it on the top of the housing and called it a day. It can't be seen once the housing is reinstalled. It's been like that for over 2 years now and no blown bulbs.
The emergency light button problem is a different issue. Your turn signal and emergency light flasher are one and the same part. And with age they eventually stop working properly. They're cheap and easy to replace.
Both of these are very common problems on C5s.
Old Sep 28, 2013 | 01:44 AM
Mew2's Avatar
Mew2
You are awesome, sweet avatar and thanks again!
Old Sep 28, 2013 | 10:14 AM
wcsinx's Avatar
wcsinx
no problem and thanks
To Right turn signal keeps going out
