vss sensor difference?
Old Sep 29, 2013 | 06:28 PM
seansz28's Avatar
seansz28
Default vss sensor difference?
I just did a diff swap into my 99 frc with 410 gears. The diff case I used was originally a 272 gear . I used the sensor that was in it from the auto. And now my speedo only works under acceleration and not under cruise or decel. I measured the sensor location and it was identical in both diff cases . Are the sensors different?
