So I am looking to up the power of my engine with a leaf blower and I want to make sure the rear can take the extra abuse. I won't be drag racing but I will be running a 315 tire and driving it hard on the road course / street fun.
I compiled a list of parts necessary for the swap and I still need to order and buy them (best place to do so??).
Anyhow, my question is, I am keeping the stock gear set in the rear, does that mean I do not need to change shims and can re-torque everything back and be good to go?
Or will some parts change my lash/clearances?
I am not trying to "skimp out", I just do not see anything in the upgrade that would effect that.
We have a bunch of differential upgrade parts on sale. If their is anything we can do for you just let us know. We carry all the parts for these differentials.
Not trying to be a smarta$$ but if you have to ask this you are probably gonna get over your head trying to do this yourself. These rears are different and require special tools and experince with them.
Strongly advise you to stick with DTE, RTK56, or RPM. I wish I had.
This is why I want to do as much research as possible before diving into it.
I have done many other rear ends before and yes this one is very finicky by design, which is a reason I was hoping I could increase the output shaft strengths, put in a better tlock and be done with it. I will be keeping the same 3.42 gears inside because I do not have the proper tools for a total rebuild.
