Spec.stage2 Clutch
Old Oct 6, 2013 | 10:08 AM
jeff keyuk's Avatar
jeff keyuk
Default Spec.stage2 Clutch
Thinking of purchasing a Spec stage2 clutch and aluminum flywheel!
Would like some feed back ! Taking out centerforce duel Friction.97C5
Old Oct 6, 2013 | 01:40 PM
racebum's Avatar
racebum
quality control use to be questionable. not sure if it still is
monster, mcloud and mantic are probably the 3 most commonly used.
what are you looking to spend?
Old Oct 6, 2013 | 02:23 PM
jeff keyuk's Avatar
jeff keyuk
Don't mine spending more ! Looking to install a good clutch! I will be doing some drag racing next summer! Thanks for the replay.
Old Oct 6, 2013 | 02:53 PM
racebum's Avatar
racebum
base the clutch off of how much torque you plan to make. the monster stage 1 can handle 450tq at the wheels and the stage 2 550. both are great quality and have been proven to take those levels of power without issue
Old Oct 6, 2013 | 04:03 PM
jeff keyuk's Avatar
jeff keyuk
thanks racebum!
Old Oct 6, 2013 | 04:17 PM
Russ K's Avatar
Russ K
An aluminum flywheel is a very poor choice for a street car. I took mine out after 2 months and reinstalled the stock flywheel. I hated it, surging/stalling/trans gear rattle when idling with the clutch engaged.
Russ Kemp
Old Oct 6, 2013 | 08:37 PM
jeff keyuk's Avatar
jeff keyuk
Thanks for the feedback Russ! Wasn't sure about the aluminum flywheel?? I have a steel one in with the centerforce clutch, Don't do much street driving ! Car will be trailer to the race track.
Old Oct 6, 2013 | 09:21 PM
racebum's Avatar
racebum
there is a happy medium flywheel. billet steel. you can get an 18lb steel flywheel that's 10lbs lighter than stock but heavier than aluminum and more rugged
Old Oct 6, 2013 | 09:40 PM
Russ K's Avatar
Russ K
My stock flywheel weighed 24 lbs.
Russ Kemp
Old Oct 6, 2013 | 09:50 PM
racebum's Avatar
racebum
Russ Kemp
gm qc
list is 28, what they really way probably varies
Old Oct 7, 2013 | 02:16 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
My choice on best pedal feel and overall performance is hands down the Mantic 9000, billet flywheel, comes with hardware-slave cylinder-throw out bearing-pilot bearing-clutch bleeder kit-and shipping within the cont US for $1,595.
Always in stock and ready to ship.
Old Oct 7, 2013 | 07:23 PM
PRE-Z06's Avatar
PRE-Z06
LS6 stock cast is 24lbs. I replaced it with a Centerforce clutch and Fidanza flywheel, then ironically a Spec Stage 2 no lie. The aluminum flywheel's 13lb weight wasn't an issue combined with the total weight of the clutch being 42lbs, but that the steel insert would warp with heat and cause disengagement issues as well as slippage from surfaces not being mated parallel which just compounded the issue. The clutch I then switched to is in my signature below and uses a Billet 18lb flywheel, let me know if you have any questions.
Old Oct 7, 2013 | 07:57 PM
jeff keyuk's Avatar
jeff keyuk
Very interesting ! 2-nice runs ,What rpm are you leaving the line???
I have a 97C5,making 430hp at the rear wheels. sent me some prices! PM me! thanks
Old Oct 8, 2013 | 09:20 PM
jeff keyuk's Avatar
jeff keyuk
Thanks guys for all the info! I will be going with the monster Level 3
Old Oct 9, 2013 | 10:39 AM
alans02z's Avatar
alans02z
Wont be disappointed. I have a couple friends that beat on theirs all the time and never had issues with the Monster 3. Just make sure to measure the preload. I had to shim both of them.
Old Oct 10, 2013 | 08:03 AM
jeff keyuk's Avatar
jeff keyuk
Thanks Alan ! Good info!
Old Oct 10, 2013 | 09:27 AM
alans02z's Avatar
alans02z
No problem! Let us know how you like it
To Spec.stage2 Clutch
