I just got an 01 with these codes.I don't have an FSM yet so what are these codes ?
28 TCS: C1214 H C
C1232 H C
C1283 H
C1296 H C
99 HVAC :
B0338 H
B0361 H C
B0441 H
AO LDCM :
B2262 H
B2264 H
U1064 H
A1 RDCM :
B2265 H
U1064 H
Also in the throttle body is this vacuum tube not connected to a hose.What hose does this connect to ?
The barb was to allow coolant to run through the Throttle Body. This is perhaps helpful for very cold climates and the car being driven in very cold air. But it is not necessary in many warmer conditions. Mine is also disconnected/bypassed, (ie the line into the TB is directly connected to the line out of the TB so no coolant passes through the TB.)
