column lock unlocking
Old Oct 10, 2013 | 02:42 PM
bob22z06's Avatar
bob22z06
Default column lock unlocking
Hey I just purchased a LMC5 and was reading the install instructions and its say u need to unlock the column before u do anything ...I hate to purchase the unlocking tool to do this can I unlock it without the unlocking tool..I just don't won't to wait..btw my stearing column locks when I take the key out...so I need some help here...
Old Oct 10, 2013 | 02:44 PM
RedZMonte's Avatar
RedZMonte
put key in ignition, unlock column, remove neg terminal from battery and remove key.. Unlocked.
Any reason that wouldnt work to unlock the column for the install?
Old Oct 10, 2013 | 03:36 PM
Macleod52's Avatar
Macleod52
I believe the reason is to permanently disable the column lock. If the relay fails (which will eventually happen) you will be stuck with no way of driving home as your steering wheel will be locked.
Old Oct 10, 2013 | 04:22 PM
65GGvert's Avatar
65GGvert
If your column unlocks when you turn the key on, you don't need the unlocker. Do as stated above and then install the LMC5 so it never relocks.
Old Oct 10, 2013 | 04:58 PM
RedZMonte's Avatar
RedZMonte
I understand why the CLB is to be installed, i was asking if unlocking it and hooking the battery would be the best way to unlock it for the install..
S
Old Oct 10, 2013 | 05:18 PM
Macleod52's Avatar
Macleod52
S
If you have the unlocker I would recommend locking the steering wheel prior to installing the LCM5. I just installed mine last night. I just figured it was easier to lock the wheel because when I got to the step of unlocking it was simple to test if it worked.
Old Oct 10, 2013 | 05:27 PM
wbrands's Avatar
wbrands
If you currently unlock when the key is turned, you should be OK to follow the instructions above, i.e. turn key, unlock column, disconnect battery (check wheel is still unlocked), and install the LMC5 per the instructions that came with it. If you have any questions, don't hesitate to call Richard at Compliance Parts, he was a great help to me when mine locked and I was stranded.
Old Oct 10, 2013 | 05:43 PM
bob22z06's Avatar
bob22z06
So thats sounds easy enough ..put the key in let the stearing unlock then disconnect battery. .than proceed with install. ..am I got this right?
Old Oct 10, 2013 | 06:29 PM
RedZMonte's Avatar
RedZMonte
sounds right to me. when its unlocked and the battery is off it should be ready to go.. dont turn the wheel to the lock position, not sure if it will relock or not.
S
Old Oct 10, 2013 | 07:11 PM
bob22z06's Avatar
bob22z06
How about the relay that's sits above BCM in instructions it shows to disconnect it in 2a step then doesn't mention about it in later steps should I leave it disconnected
Old Oct 10, 2013 | 08:27 PM
bob22z06's Avatar
bob22z06
I got it in ..took it for a test drive ..everyting seems fine ...now the column won't lock when I take the key out..is this how it supposed to work?
Old Oct 10, 2013 | 08:32 PM
bob22z06's Avatar
bob22z06
Sorry I didn't see your reply...I went and conected that relay thats above the BCM ...am I in trouble? I followed the video it didn't say anything about disconnecting that relay and leaving it off
Old Oct 10, 2013 | 11:43 PM
bob22z06's Avatar
bob22z06
K got it that clears it ...thanks for all your help
To column lock unlocking
