To start this thread, I will go through with listing things that I have already diagnosed and made sure they werent the things causing the issue.
Ok, I have a 14.4 charge coming off the alternator, battery is holding 13.8-14.0. But my dashboard volt gauge says 12.8. Sometimes goes as low as 12.2. I get a 'Charge System Fault' code every time i start the car and it seems like other stuff is malfunctioning because of this low voltage issue.
The car has a brand new GM Alternator and brand Optima Red Top Battery.
The car has always charged low since I bought it. New battery didnt change a thing, nor did the new alternater.
No offense, but are you sure you have the right alternator for your car? I went through 3 different p/n's - all recommended for my '01Z. The first one was low, the second was high with DIC messages and the 3rd did the job. True story.
I have tried multiple ones and each one has done the same thing..
