Electrical Gremlins Help
Old Oct 12, 2013 | 12:59 PM
jeffnew29's Avatar
jeffnew29
Cruising
Default Electrical Gremlins Help
I have a 2002 coupe with 97,000 mi. Car is stock with no issues when the car was purchased 2 yrs ago, but suddenly all kinds of electrical issues.
The ABS/Active handling light is on always (the dash) eventhough the module has been replaced and tested as good. Now I get no comm with the HVAC.Climate control now not functioning. All the grounds where recently checked and cleaned, including the ignition switch.
Now I have rapidly blinking dash lights and both turn signal indicators illuminated. The blinking stops when the headlights turn on.Battery is new and charged. I beleive is it some wiring/ground issue (common to ebcm/hvac) but do not know where to start.
Codes are as follows:
P0135C
P0155C
P1571
P1689
TCS NO COMM
B0432 H C
HVAC NO COMM
SDM U1040 HC
LDCM U1016H
Any ideas or thoughts would be greatly appreciated.
Thanks Jeff
Old Oct 12, 2013 | 01:14 PM
Corvette_Ed's Avatar
Corvette_Ed
Have you tried wiggling the accordion connecter between the door and the body of the car? You might need to fix a loose connection.
Old Oct 12, 2013 | 01:38 PM
jeffnew29's Avatar
jeffnew29
Cruising
yes ok just tried that on both doors. Same issues but the rapidly blinking dash lights seem now more intermittent. So strange.
Old Oct 23, 2013 | 08:27 PM
ace147's Avatar
ace147
Try the headlight switch connector under the steering wheel. Common issue.
To Electrical Gremlins Help
