Running too rich help
Old Oct 13, 2013 | 02:48 PM
Sirk17's Avatar
Sirk17
Default Running too rich help
Here is a video of a 4th gear pull from 2500 to about 5800 RPM.
As you can see the car is running rich. I have off road long tubes and vararam with power duct. Any thing I can to with out a tune and will driving it this way hurt anything. Also Im getting 30 mpg at 70mph on cruise control.
Sorry for the poor quality
[IMG][/IMG]
Old Oct 14, 2013 | 04:06 PM
RedZMonte's Avatar
RedZMonte
the car's mixure is electronically controled.. the only way to lean it out is with a tune. I cant get the video to work on my computer at work so i can really see what the video shows. if the ECU/injectors are stock with intake/headers/exhaust you should acutally be lean... but either way you should get a tune.
S
Old Oct 15, 2013 | 03:28 PM
sean.b's Avatar
sean.b
S
negative. i'd bet we're into triple digits on this being covered on these forums alone. you'll run rich after headers, despite it not making sense on the surface. whats being observed here is what one would expect.
you'll love life after getting that tuned.
Old Oct 15, 2013 | 06:22 PM
MX621's Avatar
MX621
needs a tune. ur ecu is going wtf is wrong and over correcting. remember ur ecu only has a 0-1v o2 sensor for fuel corrections. so its doing its best guess. commanded a/f on a stock tune is low 12's. so its doing best it can
Old Oct 16, 2013 | 12:28 AM
Josh@SpartanLSX's Avatar
0Josh@SpartanLSX
Former Vendor
Wow that thing is definitely pig rich.
A proper MAF calibration needs to be done first. This will then enable the PCM to accurately command the Air/Fuel ratio entered into the PCM. Without the MAF first being calibrated, A/F will still be unsteady and hard to tune and you'll experience large fluctuations like what's happening in this video. It takes more than just one adjustment to get that number to a steady & stable state across the board.
To Running too rich help
