Spec Flywheel question
Old Oct 14, 2013 | 08:15 PM
dmaleck's Avatar
dmaleck
Default Spec Flywheel question
Hey all hopefully I can get some input on this...I have a perfect spec flywheel from a twin disk sitting here and was wondering if they are interchangeable with other clutches? For example a mcleod rxt, will it bolt up to my spec flywheel? Thanks!
Old Oct 15, 2013 | 04:55 PM
PRE-Z06's Avatar
PRE-Z06
If the Spec flywheel is the same thickness as stock then it should work fine as the Mcleod is supposed to work with a stock flywheel. I would double check with the manufacturer of both though to be sure, hope that helps. Our billet steel flywheels are the same thickness as stock should you need one.
Old Oct 16, 2013 | 02:37 AM
dmaleck's Avatar
dmaleck
I ended up just buying a new clutch, I appreciate your help!
To Spec Flywheel question
