I purchased a 2002 Corvette last year and it is time to replace the tires. Up until this time I thought I had original C5 wheels on the car (front 17" and rear 18") but as it turns out the previous owner put C6 wheels on it so I actually have 18" and 19" front and rear. In doing so the previous owner changed the tire size to maintain the same original C5 height and width.
Here is the comparision of what the original C5 was, mine as it exists and the stock C6 sizes
C6 Stock Front P245/40ZR-18 25.717 9.646
C6 Stock Front P285/35ZR-19 26.854 11.220
I plan to go back with run flats ( I know this is a huge controversy but it is the route I plan to go) What I am finding is I am severely limited in choice due to the size of tire currently on the car. Front size is not a problem but the rears are.
If I change from the current 275/35-19 to a 285/35-19 my tire height changes by approx 0.275" and the width increases by 0.4"
I know I can always recalibrate the speedometer but my question to the forum is do you know if the increased height or width will be a problem fitting on the car.
Whats funny is a friend and I created a spreadsheet years ago for comparing tire size, rear end / transmission gear ratios etc and I just updated it to include speedometer error. It looks like it would be .62 MPH off
I will share that file here for anyone who wants to play with it as well.
I was mostly concerned about any clearance issues since I have not taken a close underneath to see just how close things are.
Sure hope you rethink those run flats. I've seen hundreds of posts from guys who've changed from run flats to non run flats and are so happy they did. The ride is so much better and the prices are way lower too. Either way, it's your ride and hope it works out the way you think it will. Plus you'll have a much bigger tire selection.
Castleworks, if your staying with the C6 rims/sizes, may I suggest looking at the Firestone Wide Oval RFT, made to fit C6 Corvette.
I have them on my 02 C5 with after market C6 wheels to fit C5 and they are a great tire. A lot quieter that Goodyear, good ratings, good looking too. Check out tirerack.com.
If you stick with runflats, I found the Michelins to be far quieter than the Goodyears. Rode better, didn't hunt around and chase every crack in the pavement.
