3.90 Rear End Gears
Old Oct 16, 2013 | 03:54 PM
Paul 75 L82's Avatar
Paul 75 L82
Default 3.90 Rear End Gears
I'm starting to plan my next mod and I'm thinking about changing out the 3.42's in my Z to 3.90 gears. I really only drive around town so I think it will make 5th & 6th gears more useable, plus a little more fun overall. I don't mind shifting so if the shifting increases it's no big deal. Who has changed from 3.42 to 3.90 and how do you like it?
Old Oct 16, 2013 | 03:58 PM
MStrahan's Avatar
MStrahan
I did the change and I've really enjoyed it. I had it done the same time I had a cam installed so it's kind of hard to say how much it changed because of the cam. Now I'm in the middle of a stroker build and I'm going to keep the gears.
Go for it.
Old Oct 16, 2013 | 04:19 PM
mchicia1's Avatar
mchicia1
I personally think for a c5z, it's pointless unless it's seeing the 1/4 mile on sticky tires frequently.
Gearing a car has diminishing returns just like anything else, and the c5z ratios are already like a base C5 with 3.90s 1-3.
Assuming stock red line of 6500, your first gear becomes 45 mph, your 2nd gear becomes 65 mph, and your 3rd gear only becomes 95 mph.
Where you will gain is acceleration in 4th gear.
Old Oct 16, 2013 | 04:22 PM
zeevette's Avatar
zeevette
I wouldn't do it unless you drag race alot. First gear in a M12 is 2.97:1, and with stock rear gears, is roughly equivalent to 4.30s in an old school 4 speed. The trouble with GM's choice of trans gear ratios,(nowadays) is they kept to the commonly used 4th gear being 1:1, and both 5 and 6th are OD. For street driving, all you need to do is not use 6th except on the freeway. Just my opinion, but when I went to 3.90s in my street driven Cobra, first gear was gone so fast, it was almost a waste of time, always shifting. IIRC, the old 4 spds were about 2.20 first gear. Worked great for street driving, but a change to 4.10s really made highway driving a chore w/o any OD. I guess it all comes down to racing; if you are near redline at the traps, leave it be. If you are just switching gears before the traps, go higher.
Old Oct 16, 2013 | 04:38 PM
alans02z's Avatar
alans02z
My procharged car loves the 3.90s. Once I got used to them and learned to drive the car, it feels great.
Old Oct 16, 2013 | 05:14 PM
zoomz's Avatar
zoomz
I just put 410's in my c6-z06 and it made the car drive better around town and at the 1/4 mile track .
I can skip shift 1-3-5 or 2-4-5 to 50mph without lugging the motor .
Now i can actually use 6th gear at 60-65mph , with the 342 gear i couldnt use 6th below 80mph because of the drone and rpm's .
The biggest noticable difference is the exahust drone is no longer an issue around town .
By changing the gear I did go from 15 down to 13 mpg city @ 550 rwhp with a cammed 440 stroker motor.
I should be able to run 10.20's to 10.40's now on motor and drive the car everyday and still get 24mpg@80mph :P
Old Oct 16, 2013 | 05:38 PM
Josh@SpartanLSX's Avatar
0Josh@SpartanLSX
Former Vendor
Go for it.
I heard the guy that installed your gears is a stud.
OP, gears are one of the single best modifications you can do to a stock geared LSX powered vehicle. The 3.91's in a Z06 is the sweet spot and makes 5th/6th gear usable around town. You can cruise in 6th @ 40mph with no problems.
Shameless plug. For those anywhere near the Atlanta area thinking about doing gears, we install them IN HOUSE. No diff shipping to anywhere, no additional down time, no core charges.
Old Oct 16, 2013 | 06:51 PM
Paul 75 L82
I don't make any long distance trips. Two to three hour drive would be the max. Around town if I go to 5th gear the rpm is too low. I think that the 3.90's might make town driving better. I don't race the car, I'm only a spirited driver. Most of my driving is between 45 & 60 mph. I always give the Z a Xmas gift, gears and seat covers might be this years choice.
Old Oct 16, 2013 | 08:16 PM
HoosierPE's Avatar
0HoosierPE
Former Vendor
Call DTE. Gears are what we do!
Old Oct 16, 2013 | 11:30 PM
FutureOWNR's Avatar
FutureOWNR
I just switched to 3.73 gears on my coupe, I finished with it 2 weeks ago. But I did it because I had whine and a leaky butt. I am much happier with the gears. I can actually shift into 6th at 60 MPH and 4th gear is much more fun! I was torn between 3.90 and 3.73 but I went with 3.73 because I do a lot of highway driving. I would think 3.90 would be a great upgrade for you as you do a lot of city driving.
Old Oct 17, 2013 | 08:40 AM
vettenuts's Avatar
vettenuts
I have 3.90's in my vert. It really makes fifth gear more usable and sixth gear is much much better. That said, not sure how the lower gearbox ratio's will be with the lower rear as I have the standard MN6. For me, this was a great upgrade.
Old Oct 18, 2013 | 09:58 PM
Breze84's Avatar
Breze84
I have a stage 3 DTE 3 Rib Diff with 3.90's Never installed FS if interested...
Old Oct 20, 2013 | 11:26 PM
Mike94ZLT1's Avatar
Mike94ZLT1
That's great, offer no help or insight whatsoever, just plug yourself for some work. Phil @ DTE was never like this.
I love what this forum is coming to.
To the OP... I have a base MN6 and had 3.90's. I loved them, and I eventually went with 4.10's. Definitely makes 5th and 6th gear usable. I go to Canada a lot, and their freeway speed limit is 100 kph which is 60 mph. With 3.42's I couldn't do that in 6th without it chugging. Now, it's a breeze.
Old Oct 21, 2013 | 12:30 AM
Dennis Wilson's Avatar
Dennis Wilson
I`ve had my 3.90 gears for 10 years now . Perfect for the Z! Just do it! U wont regret it!
Old Oct 21, 2013 | 12:32 AM
HoosierPE's Avatar
0HoosierPE
Former Vendor
I do apologize for that come across as It sid. You thinking is spot on. Going to a little taller gear will make the upper gears more responsive. About all you might sacrifice is fuel economy. If you are interested numbers just look at a ratio of the ratios. Divide 3.90 by 3.42 which is 1.14. At 60 the rpm will be 1.14 times faster and the rpm required to start moving is 1.14 less. Numbers don't replace feel but it at least gives you an idea.
Old Oct 21, 2013 | 08:05 AM
Paul 75 L82
Every time I drove the Z this week end I just kept thinking about what it would have felt like with the 3.90's. For around town I think it would be a thrill.
Old Feb 25, 2014 | 10:23 AM
Mickster144's Avatar
Mickster144
This was some good info. I have a C5 with a good size cam and it certainly is not fun driving in the city and of course 6 gear is useless unless you drive 80mph. I am thinking about going with the 3.90 as well. I wouldn't have had such a large cam installed if I was worried about gas mileage. Any thoughts on pricing? I have a couple quotes and they are around $2,000 installed, using RPM.
To 3.90 Rear End Gears
Old Feb 25, 2014 | 12:35 PM
Lt. Dan M.'s Avatar
Lt. Dan M.
02Z with TVS2300 /3.42s & a 99 coupe A4 headers and CAI that has 3.15s. Personally if I was going to drop $2K it would be in a cam/intake/ header upgrade (ok, maybe a little more than $2K) to give the engine more power to spinn those gears rather than change gears. Oh, I do 50mph in 6th with no problem at all. JMO
Old Feb 25, 2014 | 01:38 PM
Mickster144
I mentioned that I already did the cam. I also did the headers and exhaust. I am currently 415 rwhp.
Old Feb 25, 2014 | 03:13 PM
kromberg's Avatar
kromberg
Good lord. If you have a series 3 carrier, there is no need to replace the whole diff unit. Any competent mechanic some some experience can replace the gears for a couple hundred.
