Loose all electrical power
Old Oct 16, 2013 | 06:22 PM
Con Vette's Avatar
Con Vette
8th Gear
Default Loose all electrical power
I HAVE LOST ALL ELECTRICAL POWER WHILE DRIVING ON A FEW OCCASIONS THEN I HAVE TO WAIT ABOUT 5 MINUTES AND THE CAR WILL START UP AGAIN. HAS ANYONE HAD THIS ISSUE. ALSO IT HAS LOST POWER ON ME ONCE WHEN THE TRACTION CONTROL LIGHT CAME ON INTO A TURN.
Old Oct 16, 2013 | 06:35 PM
RedZMonte's Avatar
RedZMonte
when you say all power you mean Headlights, interior lights, brake lights, everything?
Start by checking for a bad ground. check all battery terminals (+ and - for bad connector) then start checking grounds (main battery and all). I have seen side post terminals pull out of the battery and cause a bad connection so check the battery as well.
if it doesnt have proper power the Trac Control will fail opperation as well.. power issue and TC are all related. If everything is connected well might want to have the battery tested.. could be a internal issue in the battery.
Old Oct 16, 2013 | 06:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I Agree!!! Better define ALL electrical power.
When you have the issue, does ANYTHING still function electrically? Lights, windows, ect....
If you grab the battery cables, can you move EITHER battery connection by hand??? If they move easily, thats most likely your issue. If they are tight:
Start with the battery. Remove it and have it fully Tested.
While you have it out, use a small stainless steel wire brush and clean the battery cable terminals. Flush them out with brake parts cleaner.
When you reinstall the battery terminals, TORQUE the terminals to 11 FOOT POUNDS for proper connection.
The ground terminal has two wires. A large wire that goes to the engine block and a small wire that grounds the chassis. Follow those wires and MAKE SURE that the bolt that secures the wires to the block is tight and the chassis is clean and tight.
Let us know what you find.
Bill
Old Oct 16, 2013 | 08:21 PM
Con Vette's Avatar
Con Vette
8th Gear
all power no lights nothing completely dead
Old Oct 17, 2013 | 02:51 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,,,,,,,,,,,,,,,,,,,,,, That points to a possible bad battery
OR
The battery cable terminals are too loose and not making proper contact with the battery terminals.
Clean and retorque the terminals.
BC
Old Oct 17, 2013 | 05:25 PM
Con Vette's Avatar
Con Vette
8th Gear
Thanks Guys
Old Oct 17, 2013 | 06:56 PM
CactusCat's Avatar
CactusCat
Well now, that was easy!
Old Oct 18, 2013 | 11:15 AM
dadaroo's Avatar
dadaroo
Sorry, but one idea of the Forum is post what you did to fix your problem so it can help others.
To Loose all electrical power
