how to display DIC codes.............
Old Jul 5, 2002 | 01:54 PM
rayjerman's Avatar
rayjerman
Default how to display DIC codes.............
i have a 1998 and my check engine light come on about 3 days ago and i was told that i could maybe locate the problem throught the DIC and fix it. could someone tell me how to pull up the codes through the DIC. thanks.
Old Jul 5, 2002 | 06:36 PM
Jochen's Avatar
Jochen
Default Re: how to display DIC codes............. (rayjerman)
Hi,
i copied this from a recent topic posted from ToplessTexan :
"You can access the stored DTCs by pressing and holding the 'Options' button and pressing 'Fuel' four times. From here you can page through them using the two buttons under 'Fuel'. You can clear them (and the light) by pressing 'Reset', but make sure you don't want to save any freeze frame diagnostic data first."
And here a more detailed info taken from this Forum :
"The "diagnostic display" mode is entered with the following Procedure: Page 8-500
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warning messages
3) Press and hold "options" and
4) While holding "options", press "fuel" four times within a 10-Second period.
Initially, the on-board diagnostics go into the "automatic" mode, which shows each module's DTCs in a
pre-set sequence: (Page No. are for the GM Service Manual)
10 PCNI Powertrain Control Module page 6-357 - 6-361
28 TCS Traction Control system ABS on page 5-86
?? RTD Real Time damping page 3-136
40 BCM Body Control Module page 8-405 LTD Page 8-727
60 [PC instrument Pane! Cluster page 8-508
80 radio page 8-213
99 FIVAC Heater Vent-Air Conditioning page 1-118
A0 LDCM Left Door Control module page 8-904 to 8-951
Al RDCM Right Door Control Module page 8-904 to 8-951
AC SCM Seat Control module page 8-1064-8-1082
B0 RFA Remote Function Actuation page 8-676
Hope this helps
Jochen
Old Jul 6, 2002 | 06:26 PM
C5 Frederik's Avatar
C5 Frederik
Default Re: how to display DIC codes............. (Jochen)
Hi Jochen
glad to read you. Your sig doesn´t look updated :D :D
take a look at mine.. :D ...those Stingers rock :cool:
Frederik
Old Jul 6, 2002 | 07:09 PM
Jochen's Avatar
Jochen
Default Re: how to display DIC codes............. (C5 Frederik)
Hi Frederik,
you are sooo right. the car looks much different now. Unfortunartelly i lost my password to my homepage to upload some new pics for my signature. Have to try a different way.
Hope i will come to listen to your stingers soon - Did you got my Email with the info about the crash ?
Jochen
To how to display DIC codes.............
