Can anyone explain this?
The Axles might have been siezed and not able to float wich might have made that problem. Im going to grease it up and see how it feels.
OR
Someone MECHANICALLY OVER REVED the engine by running 3rd gear to red line and selecting 2nd gear when they really wanted 4th gear.
I had the EXACT SAME wear on my centralizer and I had ZERO worn rubber couplers or bearings and the prop shaft was STRAIGHT. There was plastic inside the TT housing but not really any rubber coupler bits.
So,,,, I just reassembled it and its been fine ever since.
It had me wondering,,,,, how in the hell did someone mechanically over rev the engine. It wasn’t anything that I did and I am the original owner of the damn car.
SO,,,,,,,,,,,,,,,,,, I asked the wife..
ME: Hey honey,,, HAVE YOU,,, ever tried to speed shift the ZO6 from 3rd gear and maybe grabbed 2nd gear instead of 4th gear..
WIFE: Well,,,,,,, honey,,,,, It happened one time!!
Then I asked my Son the same question..........
SON: WELLLLLLL Maybe....
I didnt have ANY drive train issues with the drive train except that the clutch peddle would stick to the floor That I can contribute to a bad master cylinder!
I replaced the clutch, pressure plate, pilot brg, slave added a remote bleedre and installed a TRANSZILLA T60/60 MN12 trans and beefed up the rearend with C6 ZO6 parts
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
His main shaft out of the trans broke inside the Diff and did a little damage it looks like. I'm going to clean it out to make sure there are no pieces left and file down some of the damage to the housing. Then reassemble it.
Also i was looking into the axles being frozen so im going to replace those as well.
