Hypertech power programing, or not?
Old Jul 6, 2002 | 04:45 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Hypertech power programing, or not?
I already have the unit, came with the car. Its takes too stinking long to program, but I like it for changing the rear gear ratio, speed limiter, fan switch, shift points, rev limits and more.
So this is not asking to get it or not or if its worth it, but if the prower program feature can make the car run with less power? I took the power programing off, and the car feels stronger. I didn't have time to check it on the dyno when I was there (400 miles away) and I went too late, and it took to long to revert back to stock to compare it at the track today.
I'm thinking it may help a little if the car is stock? Anyone else have a few mods and try with and without the power programing? Mike at Xtreme made me start wondering about this.
[Modified by TexCorvette, 7:50 AM 7/6/2002]
Old Jul 6, 2002 | 02:50 PM
Xssesive's Avatar
Xssesive
Default Re: Hypertech power programing, or not? (TexCorvette)
Ihave read too many posts about people losing power with the Hypertech when fully installed. Chose to go with Ed Wright instead. Do a search of previous posts you"ll get more than you want to read, almost all negative. :reddevil
Old Jul 6, 2002 | 05:09 PM
TexCorvette
Default Re: Hypertech power programing, or not? (Xssesive)
thanks for the input. Anyone with solid proof like a dyno run?
Old Jul 6, 2002 | 05:34 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
You know, G-Tech has a new unit out that might be of benefit. It does a ton of things, including hp and tq, and I just ordered one yesterday. You can get one from Summit Racing. That way you could check it yourself as often as you'd like without having to go the 400 miles for a dyno. The cost is $249.95
Old Jul 6, 2002 | 05:57 PM
geekracer's Avatar
geekracer
Did your Hypertech ask you if you were running RFG (Reformulated Gasoline)? It's sold here in DFW. The RFG tuning is milder than the regular tuning.
Old Jul 6, 2002 | 06:40 PM
TexCorvette
Default Re: Hypertech power programing, or not? (MMarquez)
Cool Fundriver, so the new unit that is supposed to be enven more acurate is out already? Just need to find a road to use it on :)
Old Jul 6, 2002 | 07:26 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
I played with the engine tuning option a bit. I found that I got audible knock :eek: running ported MAF ends and a stock thermostat / fan control temps when it was hot out. The RFG tuning was a tad better. Both were livable w/o the MAF and better w/ lower fan control settings. (Keep in mind it's assumed you're running with lower coolant temps.) I never dynoed in either configuration since I mainly got it for fan control stuff.
Old Jul 7, 2002 | 10:30 AM
TexCorvette
Default Re: Hypertech power programing, or not? (ToplessTexan)
well, the car seems to pull much harder without the power tuning, just seting the gears and shift points ans such, and so did a friend, but it could just be in our heads.
Old Jul 7, 2002 | 10:41 AM
ronnie948's Avatar
ronnie948
Cruise-In III Veteran
Works Good for Me, Car is more responsive,Shifts better.and with the shift points changed it just plain feels better.I'm Happy with it. :D :flag :chevy :) :cheers: :D
Old Jul 7, 2002 | 07:03 PM
TexCorvette
Default Re: Hypertech power programing, or not? (ronnie948)
I'm happy with it too, just wondering if the power tuning aspect of it works well with a modified car.
Old Jul 8, 2002 | 08:39 AM
THRAP 42's Avatar
THRAP 42
Tex,
Not heavily modded as you can see below. But, I've got dyno sheets from before and after. Stock air box w/o programming was 287rwhp. Dropped a K&N Twin filter on and programmed - went to 297rwhp. In my case it worked fine.
later,
Old Jul 8, 2002 | 10:09 AM
ToplessTexan
That could be possible if say the engine tuning hi oct was too agressive and you feel back to using the lo oct table *and* the same was not true for the stock tuning, i.e. the stock hi oct table (or even lo oct) was somewhere in between. I'll try to find some time to take a peek at them and see. PE differences would complicate the picture somewhat. When you say "pull much harder" do you mostly at WOT or generally at all throttle positions?
To Hypertech power programing, or not?
