Transmission issue - 4th gear grind
I've done my fair share of reading up about this problem. I did a shifter alignment but it did not resolve my problem. The shifter goes into all of the gears pretty smooth(4th seems to go in fine but it grinds) so it doesn't seem to be an alignment issue but I'm no expert. I did install a Hurst short throw shifter a couple months back but this issue has only started recently. I also didn't notice any negative difference on smoothness/notchyness when moving to the Hurst shifter. I've read about changing the transmission fluid to correct the problem but wouldn't that only mask the problem if it works? It doesn't grind in other gears at all. Any guidance or information with your own experience with this situation would be helpful.
I'm assuming the worst, transmission rebuild. I do not think I have the mechanical knowledge to complete a job like that or even pull out the transmission without some soft of assistance. Another item I would like to mention is that there seems to be a lot of play within or around the transmission. It is quite noisy and after putting it in to some of the gears it sounds like 'gear chatter". Sometimes I can hear things clank back and forth a couple times after putting it in to gear and letting off the gas during casual driving. Would rebuilding the transmission tighten up those components or are those external to the transmission, clutch and other items?
Thank you for taking the time to read this!
Edit: just some relevant information, car is a 98 Coupe with 85k on the clock.
A $25 fluid change coulkd solve ALL your issues!!
You would be amazed at how NASTY your old fluid is and YES, it affects synchro operation!
The old stuff will look like dark red metal flake paint!
If that isnt the issue, you are most likely looking at a clutch that isnt fully disengaging when depressed or a synchro and or clutch fork that is/are worn.
That would require a trans rebuild.
BC
I have a question, if the transmission needs to be rebuilt and thus it will be pulled out. What other components should be replaced at that time to avoid having to drop the transmission again? Clutch and so forth?
I trust Rick Kim RKT56 with my transmission / differential needs. EXCELLENT repair and upgrade specialist!
While its out, you need to inspect and repair the following:
Replace the clutch, slave Cyl, throwout bearing, pilot bearing, add a remote bleeder.
Disassemble and inspect the torque tube bushings
Replace the clutch master cyl
Check out the following differential improvements! At a minimum, do an output shaft seal replacement
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
