C5 rear differential side gear
Old Oct 30, 2013 | 04:54 PM
elerico's Avatar
elerico
Default C5 rear differential side gear
on my 3.15 diff, the wheel on the driver side sometime LOCK and make a big clunk
when its happen, the wheel grip on the groiund and make a small tire burn..
where i can find sidegear ?
i look over internet and CANT find nothing..
thabks !!!
Old Oct 30, 2013 | 05:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What country are you located in?
Before you get too deep into differential repairs,, lets look at some other common stuff that can cause issues
WHEEL HUBS
I would check each wheel hub for excessive play. Jack one rear wheel and grip the tire at the top and bottom. PUSH + PULL on the TOP & BOTTOM and see if there is ANY play in the rear wheel hub. There should NOT be any.
While that wheel is off the ground, put the trans mission in neutral and see if you can turn that wheel. It SHOULD be difficult to turn. If its easy to turn, you most likely have a broken Belliview Spring and or severly worn clutches.
Do the same for the other rear wheel.
Do you hear ANY abnormal noises in the rear?
Do you hear any abnormal noises when you turn left or right?
Check the CV Joints for damaged boots and leaking grease and make sure there isnt any lost motion in either joint if you grasp the propellor shaft and pust pull it.
Have you ever changed the differential fluid? If not, it woulkd be wise to repolace it with 75/90 GL5 differentil lube.
Here are sever al post that will allow you to see how the C5 differential is constructed and how easy it is to UP-GRADE with better parts:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Bill
Old Oct 30, 2013 | 06:18 PM
elerico's Avatar
elerico
Im in canada
Already change the diff
To a 3.42
Just want to rebuild this one
No trouble with the new one
Old Oct 30, 2013 | 09:20 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The POST that I gave you should be all that you need.
Gene Culley www.gmpartshouse.com and DTE have anything that you need to upgrade
If you replace the pinion parts or ring gear or bearings, you MUST have the Kent Moore tool to align the gears.
Old Oct 30, 2013 | 11:03 PM
elerico's Avatar
elerico
I cant find side gear. Do you have a direct link
Old Oct 30, 2013 | 11:51 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do you need the LEFT (drivers ) side gear or the RIGHT (Passengers ) side gear??
BC
To C5 rear differential side gear
