What functions does the clutch safety switch do
Old Oct 30, 2013 | 08:47 PM
bobby777's Avatar
bobby777
Default What functions does the clutch safety switch do
I know it starts the car but does it turn on the fuel pumps also?
Old Oct 30, 2013 | 09:21 PM
RedZMonte's Avatar
RedZMonte
fuel pumps should be activated with the ignition switch. Clutch switch should only allow you to start the car and deactivate the Cruise control if set. (im sure it does other things but nothing to do with the fuel pump)
Old Oct 30, 2013 | 10:10 PM
bobby777's Avatar
bobby777
Thx.--do you think it has anything to do with pressurizing the injectors - before the car starts?
Old Oct 31, 2013 | 07:41 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
No. It's main function is to make sure you can't start the car in gear, and immediately ram something. Kicking off the cruise control is it's secondary function, no more, no less..........
Old Oct 31, 2013 | 08:43 AM
bobby777's Avatar
bobby777
Thx guys--got it
Old Oct 31, 2013 | 01:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The CLUTCH SAFETY SWITCHs ONLY functuin is to make sure that the clutch is fully depressed during cranking the engine. Its a TWO WIRE switch on the fire wall and disables the power to the Theft Deterrent Relay operating coil.
The Cruise Control switch is on a bracket and contacts the clutch peddle arm when the clutch is fully RELEASED. If you put your foot on the clutch peddle, sometimes its enough to disengage the cruise.
Old Oct 31, 2013 | 02:02 PM
Navybluevette's Avatar
Navybluevette
St. Jude Donor '12-'13-'14-'15-'16-'17
Mr. Bill is correct.....
To What functions does the clutch safety switch do
