LS7 rockers
Old Oct 31, 2013 | 09:10 AM
1972bluelt1's Avatar
1972bluelt1
Default LS7 rockers
just reading about rocker arm failures on LS7s.
Just purchased a 2007 with 7000 miles. It was built in Aug of 2006.
Would it be a good idea to install a comp cams rocker arm trunion bearing kit?
Thanks,
Old Oct 31, 2013 | 09:15 AM
sunchaser73's Avatar
sunchaser73
You may want post this in the C6 Tech section...not C5
Old Oct 31, 2013 | 02:16 PM
Pumba's Avatar
Pumba
Yes, you can. You should upgrade your stock LS7 rocker arms with either the Comp kit or the C.H.E. Precision upgrade - http://cheprecision.com/html/home.html
Good luck with your decision.
Old Nov 1, 2013 | 07:06 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I took a real hard look at the CHE upgrade, if for no other reason that it's so cool. However, "cool", in this case, doesn't come cheap, and after some serious thought, I purchased the Comp Cams trunnion kit instead, and installed it myself.
To LS7 rockers
