I am completely stumped-IPC OUT
Brother,,,,,, You need a meter really bad.
With a DC Volt meter, read the following:
1. Battery voltage directly on the battery terminals engine running. If you want to read the same while you are driving down the road, measure the output of the Cigar lighter or the hot at all times AUX wire in the passengers foot well.
Battery voltage feeds the HOT AT ALL TIMES buss in each fuse box>
Both fuse boxes have a B+ stud. The battery RED positive has TWO wires. One goes to the starter and the other goes to the B+ stud on the fuse box in the engine compartment.
You will find TWO wires on the stud. The other wire feeds the passengers fuse box.
What ever battery voltage is RUNNING OR ENGINE OFF, you should read that voltage on the B+ fuse block feed.
2. Hot in ON and START or HOT in ON and RUN comes from the IGNITION SWITCH. It feeds all the modules that have dual power supplies. BCM, PCM, IPC, DCM SCM ect
These are the feeds off the ignition switch. This is from a 99 C5:
In you C5, The IPC is powered by TWO fuses from the I/P Fuse Box Fuse# 19 is the IGNITION SWITCH powered fuse and Fuse# 25 is the HOT at ALL times fuse.
On top of EACH fuse are two slots. Those are TEST points that you can read with a meter. Read fuse 19 to chassis ground when the issue happens. As long as the ignition switch is ON, you should read full BATTERY VOLTAGE on that fuse. If it is a lot lower or absent, that is a problem.
3. Serial data buss. If you pop the top off the the STAR Connector that has FOUR wires in it, you ISOLATE the LDCM, RDCM, and the Seat Module from the rest of the serial data wires.
Those three modules are or can be the cause of corrupt data on the serial data buss. Remove the shorting buss from that connector and see if the issue still happens. Post results. Yes you can drive the car with that disconnected.
4. Ignition switch HOT in ON and START feeds.
That switch gets its power from the HOT at ALL TIMES buss. Look carefully at the two connectors that the ignition switch connects to. Look for bent pins, corroded pins, melted pin sockets, There are some bent female pins in this ignition switch connector that caused a low voltage issue:
Test that stuff and see what you find.
Bill
Except for you folks, I am on my own, as locals are clueless.
I am really grateful for all the responses and will begin to track it down
Actually, I am learning a lot and it is empowering and fun.
Dave
It is a good view for us very novice, low on theory and skills, want to be electrical DIY ers.
Since you're already talking to Dadaroo work through what he suggests and post up what you find.
http://www.decouplerpulley.com/files/RotoRxbrochure.pdf
Look at the IDP description on page 4 and the "what to look for" text on page 5.
I think your conclusion that the decoupler pulley is causing your low idle voltage may be wrong. If it is correct, then the pulley is slipping.
Bill
Which connector???? The one that comes off the Sensor on the end of the Ignition switch?
How many wires on the connector. Take a picture of it if you can.
Bill
Still working to find the IPC going in and out problem. Wondering more and more if it is the BCM. Still need to do a number of voltage and continuity checks and look at ignition plugs and IPC plugs.
Sam is off line for awhile. Anyone?
Pop the top off the STAR bus connector with FOUR WIRES and see if the issue goes away.
Bill
Other than disconnecting the batt ground, I did not touch any major grounds or hots.
Going to go get a battery charger.
Have someone attempt to chank the engine and see what that voltage does.
BC
Can you move any of the battery cables on the battery by hand??? If so, thats your issue.
BC
