Time for a new clutch??
Old Nov 5, 2013 | 08:06 PM
Mickeyrx70's Avatar
Mickeyrx70
Default Time for a new clutch??
I have an '02 Coupe with nearly 92k miles. The clutch pedal sometimes sticks, usually about half way up, but a couple of times it's stuck all the way down. I've flushed the clutch reservoir more times than I can remember, even using the "modified ranger" method of inserting a tube inside the line at the bottom of the reservoir and flushing until the fluid is spotless, but the resulting improved pedal response is only temporary at best. This condition started about 2 weeks ago & is getting worse. There is no fluid loss in the clutch reservoir. Is it time for a new clutch?? Thanks for any help!
Old Nov 5, 2013 | 09:24 PM
racebum's Avatar
racebum
stock clutch can do that regardless. i remember when the c5 was a new car and guys would track them. same complaints, especially when the power went up. it does seem to get worse with age.
the choice you have to make is
1. do you want an ls6 clutch? 10lbs lighter than the ls7 but reduced power holding
2. the ls7 clutch, more power holding but that heavier assembly slows down throttle response
3. a monster stage 2. this can be the lightest combo of all with their billet flywheel. can handle the most power but also will be the quickest engaging or the 3 and potentially have some shudder...i'm still wanting to drive one of these before i install the one i have sitting here to see what it's really like
Old Nov 5, 2013 | 09:44 PM
dr_whigham's Avatar
dr_whigham
Originally Posted by racebum
stock clutch can do that regardless. i remember when the c5 was a new car and guys would track them. same complaints, especially when the power went up. it does seem to get worse with age. the choice you have to make is 1. do you want an ls6 clutch? 10lbs lighter than the ls7 but reduced power holding 2. the ls7 clutch, more power holding but that heavier assembly slows down throttle response 3. a monster stage 2. this can be the lightest combo of all with their billet flywheel. can handle the most power but also will be the quickest engaging or the 3 and potentially have some shudder...i'm still wanting to drive one of these before i install the one i have sitting here to see what it's really like
Having had a Monster stage 2, I can say this.
You won't notice the slightest difference from stock, other than you don't get locked out of gear at high RPM, and you have great holding power and can actually feel your cars power.
There's absolutely NO SHUTTER WHATSOEVER!!! It's not a ceramic clutch. It's a Kevlar/organic. It's perfect. Kevlar for longevity.
Someone on here keeps saying Monster has a new stage 2 that's all organic. Ok. Why? I haven't heard that at all. I guess if you want a clutch that will hold what you want, buy wear out faster, then get it.
Good God folks. Get away from the self adjusting pressure plate (LS6/7 clutch)
Old Nov 6, 2013 | 02:01 AM
racebum's Avatar
racebum
have you talked to the guys at monster in the past few weeks? they will tell you the same thing, look at the website, it's been updated. the new clutch is a carbon organic blend that from what i gather is superior to the old dual friction design
Old Nov 6, 2013 | 05:03 AM
Mickeyrx70's Avatar
Mickeyrx70
How about the LS7 clutch with the Fidanza flywheel? The Fidanza weighs 12.9 lbs.
Old Nov 6, 2013 | 09:28 AM
dr_whigham's Avatar
dr_whigham
I have, I probably just didn't see it. I looked at ticks website as well and saw no mention. I find it interesting though, that's for sure.
Old Nov 6, 2013 | 02:27 PM
racebum's Avatar
racebum
http://www.monsterclutches.com/shop/...5-package.html
give chris a ring at monster clutch direct, he'll give you the run down, you may notice if you read all the new text, top to bottom the word kevlar doesn't exist anymore in the lower paragraphs
Old Nov 6, 2013 | 02:32 PM
racebum's Avatar
racebum
that's the only way to use an ls7 clutch and keep the weight down. if you want a clutch that drives just exactly like stock this is how you do it. one of my personal friends beat on an ls7 clutch for a year and had no issue with it.
Old Nov 7, 2013 | 04:46 AM
Mickeyrx70's Avatar
Mickeyrx70
Thanks for the advice. I'm likely going with the LS6 or LS7 with the Fidanza flywheel -- leaning slightly toward the LS7. I appreciate the input.
Old Nov 7, 2013 | 07:56 AM
1sickz51vette's Avatar
1sickz51vette
I went with a centerforce II organic disc/pressure plate and fidanza flywheel. I didnt notice ANY difference in revs, but now it chatters a bit... Only at certain times which is weird, and is starting to in reverse now as well.
Old Nov 7, 2013 | 02:17 PM
racebum's Avatar
racebum
if you can swing the $ i would. it's designed for more power and more rpm. you may have noticed your stock clutch is fine unless you spin it to 6500. lot of times they even work going to 5500 and through the gears. for some reason rpm seems to have an impact. beings the ls7 clutch was designed for more torque and 500 more rpms it's not a bad fit in an ls1/6
the next step up in strength from there is the monster stage 2 which gets rid of the self adjusting pressure plate and brings the total weight down to 43lbs
Old Nov 7, 2013 | 03:15 PM
rttmike's Avatar
rttmike
I am over 400 rwhp with an ls7. I'm happy so far.
Old Nov 7, 2013 | 07:13 PM
PRE-Z06's Avatar
PRE-Z06
Just to share my experiences, I've ran a Fidanza flywheel with an organic friction, kevlar friction and ceramic friction...all of which left the steel insert warped and a disengagement issue when heat was introduced from launching the car, that is why we run a billet steel flywheel even for our lightweight setups. For clarification an LS7 weighs ~57lbs and an LS6 weighs ~50, our 28lb setups vary from 52-54lbs depending on the disc and the 18lb setups are between 42-44lbs again depending on the disc used. Feel free to contact me with any questions, hope that helps.
Old Nov 8, 2013 | 08:20 PM
Mickeyrx70's Avatar
Mickeyrx70
Update : I opted for the LS7 clutch without the Fidanza flywheel. The clutch kit should be here next week. Thanks for all the advice!
Old Nov 8, 2013 | 10:38 PM
dr_whigham's Avatar
dr_whigham
Congratulations. You've opted for a clutch with a self adjusting pressure plate that will stick your clutch to the floor under high RPM load.
Why? Why when the Monster is roughly the same price, and you get a better product?
Old Nov 9, 2013 | 09:52 AM
ZZ06's Avatar
ZZ06
.......awwooo that shouldn't b funny but, I digress Monster FTW!
Old Nov 9, 2013 | 10:05 AM
dr_whigham's Avatar
dr_whigham
Going back and reading that in the light of day does look a bit brash and I apologize. I didn't mean it like "that"...
I just hate seeing people spend money twice. I've fought this battle before, and have helped way too many people in the past with the same issue.
Change everything hydraulic wise to brand new, still sticks. Drill mod the master, still sticks. Upgrade to a Tick master, STILL STICKS.
Get rid of the damned GM self-adjusting pressure plate... Problem SOLVED. It's the pressure plate that makes it stick like that. Period. It's not a sales pitch or sales ploy. It's fact.
I just wish you'd have went with ANYONE other than GM.
To Time for a new clutch??
Old Nov 9, 2013 | 12:08 PM
lionelhutz's Avatar
lionelhutz
I agree that Monster isn't much difference once you add the slave, throwout bearing, pilot bearing etc that you still need to buy with the GM clutch. Everyone posts good things about Monster clutches too.
Old Nov 9, 2013 | 03:08 PM
Mickeyrx70's Avatar
Mickeyrx70
I asked for opinions and I appreciate you taking the time to offer yours. Sorry you so strongly disagree with my choice., but the decision is made. Maybe the results won't be as dire as you predict.
Old Nov 9, 2013 | 03:21 PM
racebum's Avatar
racebum
it's a pros and cons thing. the ls6 and ls7 clutches are going to win the ease of engagement contest over any aftermarket clutch. if someone drives on the street, in rush hour traffic and parking lots 99% of the time it may not be a bad choice. let's not ls7 clutch bash too bad. lot of guys running low 12s have hammered on that clutch and it hasn't failed. probably not the best choice for slicks, no lift shifts or high hp, but, if someone wants a clutch that feels just like factory it's going to give them exactly that
i love the guys over at monster clutch and think they have top tier customer service and an excellent product. it just may not be the best choice for every single c5 owner out there
