Headlight stuff
Old Nov 6, 2013 | 10:11 AM
CycledeLex's Avatar
CycledeLex
Default Headlight stuff
So, After a spirited run last night with some friends, It seems after we got to our destination, the driver light wouldnt go back down. I tapped it a few times, and it popped back down. Later after driving around town, maximum speed of 50 or so, it operated normally. THEN on the way back home( spirited driving again) the same light wouldn't go down again. I tapped a few times and down it went. NOw I'm wondering if this has to do with the speed involved? Does high prolonged speed overextend the light in its housing or something? Because after I tapped it a few times, I did a couple of cycles and they worked just fine. Or is it just time to have to make repairs? 03 C5
Old Nov 6, 2013 | 11:27 AM
dadaroo's Avatar
dadaroo
I would forget about whether speed has anything to do with it. You appear to have a mechanical issue in my opinion if you can tap it and have it go down. The control module activates the motors to go up or down. The motors shut off when the module senses high current because the buckets hit the stops. You do not want to damage a motor because it is running and trying to change position and it can't. Not a headlight expert but I do understand the basics of proposed operation. If anyone has another reason please feel free to chime in, I will not be offended.
The only other thing could be a bad motor where the brushes need a little help in rotation to get going but I would think this would affect opening and closing. sounds more like a gear related issue at the up position. Let us know what you find.
Old Nov 9, 2013 | 03:33 PM
CycledeLex's Avatar
CycledeLex
So, after doing some testing, I have come up with more results to help pin this down. It doesn't seem to happen during the day when its warmer. The only other time it has had a problem was on a cold night in the low 40s. Also, I have noticed that the driver side seems to open and close slightly slower than the passenger. I just went to test this a few minutes ago and the first two times, it was very much slower.
BUT
After cycling a few times it caught up. And after several cycles it opened and closed normally. I didn't hear any loud grinding or popping.
I also have to admit that in the first post, the tapping may not have had anything to do with getting it down. because I tapped it, THEN cycled the lights.
Old Nov 9, 2013 | 05:29 PM
lionelhutz's Avatar
lionelhutz
It's probably a gear just like the 1000's of other threads on the subject of sticking headlights here.
Old Nov 9, 2013 | 06:40 PM
CycledeLex's Avatar
CycledeLex
ok, just wanted to make sure before i waste my money on something thats not the problem
Old Nov 10, 2013 | 10:56 AM
CactusCat's Avatar
CactusCat
Ok before you start throwing $$ at it, try some simple things. There are actuator arms (from motor to headlight module) that for various reasons might be binding slightly. Take the black light cowl off (3 phillips screws) and then spray some WD-40 or such on the pivots on the actuator arms. Also, just for funnies, there are several insulator bump stops on the headlights (if I remember correctly, 2 on the back and 2 on the side) and they simply push onto a flat metal connector. Try taking those off and turning them over as well. I like to try and get stuff working correctly without spending much if possible. Good luck.
Old Nov 15, 2013 | 07:57 PM
CycledeLex's Avatar
CycledeLex
Thank you veru much Cactus cat, for your well informed and thought out response. I'll check that immediately. If that doesn't work, I'm leaning towards a new motor. Because I can screw the light just fine manually, the intermittent nature of the problem, And I dont hear noises.
Old Dec 1, 2013 | 04:51 PM
CycledeLex's Avatar
CycledeLex
OK, so I am seriously on the fence about this driver light now. Before it was just affected by cold. And only happened intermittently. NOw it just full on won't open. I'm very unsure as to whether it is the actual motor or the gear. I can manually open and close it from under the hood without problem. Now though, the light just wont open. When I flip the switch it just clicks once.just once.(Similar to a car trying to start with a dead battery). I can see the manual **** on the motor twist about 1/8 a turn and stop. NO other noises. no grinding or whirring. I dont want to buy a new gear and then turn around and have to get a whole motor. Any ideas?
Old Dec 2, 2013 | 07:57 AM
dadaroo's Avatar
dadaroo
Most likely it is the motor since you can manually operate them and the module sends a signal to open and the motor tries a little. To rule out the module you can just jumper 12 volts to the motor, or remove it and test it on the bench. There are no limit switches to limit door movement. The module just senses high current when the door hits the stops and it shuts off the motor.
To Headlight stuff
