Headlight Flops
Old Nov 7, 2013 | 06:59 PM
3pedal_z06's Avatar
3pedal_z06
Default Headlight Flops
One of my headlights works as normal, the other is no longer connected. The light comes on, but the PS light stays down. Except when I go over a bump, and then it might flop up on its own, weather the light is on or not.
I assume some kind of gear problem, but none of my Vette friends have seen this.
Anyone see it, have any ideas?
Old Nov 8, 2013 | 09:03 AM
69autoXr's Avatar
69autoXr
At one point I lost the pin connecting the motor actuator rod to the underside of the headlight assembly. Sounds like this is a possibility in your case since the headlight will flop on it's own over a bump, mine did this as well.
I can say that the headlight motors and mechanisms on my car have given me the most trouble compared to anything else on the car. Makes me wish it was a C6 in that regard.
Old Nov 8, 2013 | 12:32 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Originally Posted by 69autoXr
At one point I lost the pin connecting the motor actuator rod to the underside of the headlight assembly. .
Not uncommon. Same thing happened to me. Replace the missing pin and nut.
rr
To Headlight Flops
