Pfadt spanner wrenches
Old Nov 10, 2013 | 12:12 PM
Cedarberry's Avatar
Cedarberry
Default Pfadt spanner wrenches
Anyone know where to get a set of these. Purchased used coilovers and they didn't come with wrenches. Even some aftermarket wrenches would be fine
Old Nov 10, 2013 | 07:21 PM
Cedarberry's Avatar
Cedarberry
Ill rent a set from you
Old Nov 10, 2013 | 07:52 PM
m6 c5's Avatar
m6 c5
Pfadt doesnt make them anymore from what they were telling me, I was directed to get a spanner wrench off line. I didnt want to spend the money that most places wanted for one so I had just been using a screwdriver and rubber mallet.
Old Nov 11, 2013 | 07:26 PM
Rookieracer's Avatar
Rookieracer
I ordered a set of these today. I'll let you know if they fit.
http://www.summitracing.com/parts/hal-t114w/overview/
Old Nov 12, 2013 | 01:57 PM
Cedarberry's Avatar
Cedarberry
sounds good ill hold out till then
Old Nov 12, 2013 | 02:14 PM
StingrayRebel's Avatar
StingrayRebel
which coilovers did you get?... I bought some featherlights and they don't use a spanner wrench anymore, there is one tool that has a hex on one end to tighten the lock down screw on the ride height adjusters and the other end is round and fits in the small holes around the ride height adjusters... basically you just insert the round end in those holes and use it to raise/lower the adjusters... if yours are set up like this you could use a t-handle or hex socket for the lock down screws and a punch or philips screwdriver to adjust the ride height
Old Nov 12, 2013 | 02:39 PM
Rookieracer
Looks like it shipped from Summit's Nevada warehouse and according to the tracking # will be here tomorrow.
Old Nov 13, 2013 | 10:51 AM
Cedarberry's Avatar
Cedarberry
First gen pfadt
Old Nov 13, 2013 | 10:52 AM
Cedarberry's Avatar
Cedarberry
Nice, lookin forward to see if they work
Old Nov 13, 2013 | 01:36 PM
Rookieracer
The "QA1 Coil-Over Shock Adjusting Tools T114W" didn't work.
I found some at McMaster Carr. Should be here late today or tomorrow.
Old Nov 13, 2013 | 01:48 PM
Rookieracer
For those of you following along. The two adjusting/lock nuts on the First Gen Pfadt coil overs are a 2.5" circle and a 2.9" circle. A lot of the wrench companies don't list the size.
Looks like Summit has one from Pro shock that is 2.5". # PFI-Z902 at $9.97
Old Nov 13, 2013 | 10:33 PM
Rookieracer
Talked to Pro Shock. That wrench is a no go.
The ones from McMaster Carr came in. They are perfect. http://www.mcmaster.com/
Part #6975A19
Fixed Hook Spanner Wrench For Slots, For 2-9/32" To 2-7/16" (58mm To 62mm) Circle Dia. $23.02
Part #6975A21
Fixed Hook Spanner Wrench For Slots, For 2-43/64" To 2-61/64" (68mm To 75mm) Circle Dia $23.77
Old Nov 14, 2013 | 09:39 AM
Cedarberry's Avatar
Cedarberry
Part #6975A19
Part #6975A21
sweet, thanks for all the help in locating these wrenches, much appreciated
To Pfadt spanner wrenches
